Question about IBM PS/2 Enhanced Keyboard/Mouse 71G5791
No matter what key I press the computer scrolls uncontrollably
  • 3,153 Answers
This is usually a signg of either a stuck membrane switch or an incorrect switch setting if you have installed the specific software for that device.
If its a setting you can open the specific software eg. Microsoft mouse or keyboard and use the "reset to default" option
If however it is a stuck mebrane then you have two choices. One is to strip the device down and look for the cause and clean and see if it fixes it OR replace it.
The cost of most input devices means replacement is quite often the better option.
If it is still under warranty then simply take it back for an exchange.
Bob
Posted on Sep 08, 2010
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
How to use Samsung C3050 as a modem??? I have all necessary drivers on my PC including Samsung Mobile USB modem... WHAT SHOULD I DO??? PLEASE HELP ME
Dear dabblrx. You may follow these steps.
-Press the Navigation key to access the main menu.
-Scroll to Applications and press the Navigation key.
-Scroll to Bluetooth and press the Navigation key.
-Press Options.
-Scroll to Settings and press the Navigation key.
-Scroll to Activation and press Navigation key right to select On.
-Scroll to My phone's visibility and press Navigation key right to -select On.
-Press Save.
-Start the GSM dial-up connection (C3050 GSM) you have set up on your computer.
-The display shows that the number is being dialled.
-When the connection is established, you can access the Internet from your computer.
By the steps above, you can use your Samsung C3050 as a modem successfully. May this article can help you.
Jun 19, 2011 | Samsung C3050 Cell Phone
The most common cause of the problem is a stuck/shorted button either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control battery or put it away from the television. Press the menu button on the television and check if the menu scrolls by itself. If yes, the DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Jan 16, 2010 | Haier HP42BB 42 in. Plasma TV
My Logitech mouse is uncontrollable. I changed
It's probably one of two problems. Either you have spyware (install and run SpyBot, for example) or the scroll button is pressed too hard. Good luck.
Jun 24, 2009 | Logitech Cordless Mouse
Won't scroll to top of page. Stuck at the bottom! Fixed momentarily by pressing scroll lock key or F7 key, but goes back to the bottom seconds later. (I also have issues with the F7 key, and the touchpad...
It sounds like your scroll lock key is stuck on. Press the Function key and the scroll lock key at the same time and this sound turn off the permanent scroll lock.
Feb 27, 2009 | Acer Aspire 5570-2758 Notebook
Uncontrolled scrolling in excel
You System has been attacked by a virus or bug try scanning your PC in safe mode with the latest dat file of MC afee or trend micro. I have faced a similar problem recently and and have got rid of it this way only. Good Luck
Oct 08, 2007 | WYSE Winterm S30 Network Terminal
Settings for mms
Setting up MMS
The WAP will need to be setup before MMS can be activated. Please follow Setting up WAP
guide before MMS.
1. From the main display press the left select key under Menu.
2. Scroll to Messaging and press the left select key under Ok.
3. Scroll to Settings and press the left select key under Ok.
4. Scroll to Multimedia Message and press the left select key under Ok.
5. Scroll to Network Profile and press the left select key under Ok.
6. A list of profiles will be displayed, press the left select key under Options.
7. Scroll to Add and press the left select key under Ok.
8. Profile name will be displayed, enter Vodafone MMS and press the left select key under
Ok.
9. Scroll to the New Vodafone MMS profile and press the left select key under Options.
10. Scroll to Settings and press the left select key under Ok.
11. Scroll to MMSC and press the left select key under Ok.
12. Enter http://mms.vodafone.co.uk/servlets/mms press the left select key under OK.
13. Scroll to Internet Mode and press the left select key under Ok.
14. Scroll to WAP and press the left select key under Ok.
15. Scroll to Proxy IP and press the left select key under Ok.
16. Enter 212.183.137.012 press the left select key under OK.
17. Scroll to Proxy Port and press the left select key under Ok.
18. Enter 8799 press the left select key under OK.
19. Scroll to Connection and press the left select key under Ok.
20. Scroll to Vodafone GPRS and press the left select key under Ok.
Note: If there is no Vodafone GPRS settings please follow Setting up WAP guide.
21. Press the Right select key under Back.
22. Scroll to Vodafone MMS and press the left select key under Options.
23. Scroll to Activate and press the select key under Ok.
Once you save the settings for MMS then the settings for GPRS are given below:
Setting up GPRS
2. Scroll to Settings and press the left select key under Ok.
3. Scroll to Connectivity and press the left select key under Ok.
4. Scroll to Network and press the left select key under Ok.
6. Scroll to Data Connections and press the left select key under Ok.
7. Press the left select key under Options.
8. Scroll to New Profile and press the left select key under Ok.
9. Scroll to Name and enter Vodafone GPRS
10. Scroll to Bearer and scroll left/right to GPRS
11. Scroll to APN and enter:
For PAYT customers: pp.vodafone.co.uk
For Contract customers: wap.vodafone.co.uk
12. Scroll to Use ID and enter wap
13. Scroll to Password and enter wap
14. Press the left select key under Ok.
15. Press the Hangup key.
16. From the main display press the left select key under Menu.
17. Scroll to Browser and press the left select key under Ok.
18. Scroll to Settings and press the left select key under Ok.
19. Scroll to Network Profile and press the left select key under Ok.
20. A list of profiles will be displayed, press the left select key under Options.
21. Scroll to New Profile and press the left select key under Ok.
22. Scroll to Name and enter Vodafone WAP
23. Scroll to Homepage and enter http://live.vodafone.com
24. Scroll to Proxy and scroll left/right to On
25. Scroll to IP Address and enter 212.183.137.012
26. Scroll to Port Number and enter 8799
27. Scroll to Access Point and scroll left/right to Vodafone GPRS
28. Press the left select key under Save.
29. Scroll to the New Vodafone WAP profile and press the left select key under Options.
30. scrollto Activate and press the left key under OK.
if it asks you for a PIN. The PIN is 1234.
Oct 07, 2007 | LG Shine KE970 Cellular Phone
Uncontrolled scrolling within excel app
Try pushing in on the scrolling ball on the mouse.
I just had the same issue and that's what I did and it quit.
Hope this helps!
Sep 11, 2007 | WYSE Winterm S30 Network Terminal
Computers & Internet Logo
16 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
