Question about Bosch Classixx WFL 2066 Front Load Washer
Unable to use washer due to key logo 'flashing'. Have checked the plug at bottom right of machine no blockage there.
    President:
  • 1,932 Answers
Please try this
the key and flashing = child lock.
close washing machine door, turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Than You
Posted on Sep 08, 2010
Mid cycle it turns off and beeps and the anti crease/end button flashes
Possibly a blockage pump or drain outlet, check the filter behind the flap (bottom right on the kick panel).
May 31, 2013 | Bosch Logixx WFT 2806 Front Load...
Kenmore front load 110.46462501 mid cycle all lights flash won't drain
Check your drain pump/filter may be located bottom right of machine/hold drain hose over bucket with around 2 feet from floor level should pump if no blockage....Remove any blockage .hope this also solves tray fault
Jun 27, 2012 | Kenmore Front Load Washer
The washe is flashing F-21.
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Whirlpool AWM9000 Front Load Washer
Hi got hotpoint aquarious wmf740. all lights flashing f-05 ? wont spin or drain. please help
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer.
Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps...
Daniel
Aug 30, 2010 | Washing Machines
Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Jul 12, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a Creda 1200 washing machine, I am unable to locate the fluff filter. Does my machine have one? if not, what happens to dogs hairs etc? will they damage my machine?
The filter is at the rear of the washer.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well..
Please rate my solution.
Thanks.
Jan 17, 2010 | Creda W120VW Front Load Washer
Water will not drain, drumb won't spin
check water pump for faults and or blockage it will not spin as there is to much water inside once it has drained it should spin this is a safety feature
Jan 15, 2010 | Kenmore HE2 Plus Front Load Washer
Unable to open door
You will have to pop off the panel on the bottom right of the front of the machine. Inside you find the pump. You will have to make the pump work manually (Look out for the flood.) Once you have drained the water, then the door should open.
Jan 10, 2010 | Bosch WFMC 3200 Front Load Washer
F5 flashing and machine wont empty help
F05 means pressure switch jammed on full.
Do the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.Reassemble, and test.
Thankyou.
Dec 29, 2009 | Hotpoint Aquarius WD640 Front Load...
4 flashes and beeping
4 flashes indicates a drain failure. Could be obstruction in drain system-first check drainhose for kinks, check where drain hose attaches to wastepipe spigot for blockage. If OK blockage may be in pump- disconnect from power, remove bottom panels to access under machine. Drain pump located front left- remove plug from pump, then there is a plastic tag on top of pump you must push down, then drain pump will turn and come off (it comes off easily if tag pressed correctly, so don't force it!!)
If pump OK, fault will be with water indicator switch-sometimes get full of muck. Open dishwasher door, remove filters and clean out any water from base. Right in the bottom right hand side of sump you will see a round black grill- this is water level indicator switch. If it looks blocked up, advise replacing (you can try cleaning, but replacing is best). To replace, access from under machine-again, this switch turns and pulls out, but can be quite difficult due to it being located behind the heating tube.
So, check hoses and pump, then press and hold start button for 3 seconds- this clears fault and resets machine. Try another cycle-if OK, problem solved. Recommend expert assistence to replace water indicator switch.
Aug 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Bosch Classixx WFL 2066 Front Load Washer Logo
182 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
