PROTECT is flashing on our Sony Digital Audio/Video Control Center
  • 10 Answers
PROTECT means the receiver is automatically powering down to protect it's amplifiers. Top reasons are overheating, which can be caused by poor ventilation, covering vent holes, excessive volumes for long periods of time, or it's actually just that hot in the room, which, with the current weather, I've encountered in clients homes before. The other option, and just as common if not more so, is that the speaker wire outputs are shorted out and are causing the amp to turn off. The easiest way to test this is unplug all of the speakers and turn it back on. If it still says protect, then it's either too hot or there is a physical problem with the protection circuit and needs to be serviced (this would be a good time to kick yourself for buying a sony receiver). If it DOES power on, plug in the speakers one by one, and if the amp goes into protect mode as soon as you plug in a speaker, it's an issue with that one. Check for short circuits in the line (kinks, frayed ends, staples going clear through the wire, etc). If the wire looks good, try putting a different speaker at the end. If a different speaker works, then the speaker is blown, which gives 0 continuity, and the receiver is correctly protecting itself from the high impedance load. Change the speaker.
Posted on Sep 08, 2010
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
I have a Sony audio control center receiver I replaced the 6.3 A 125 fuse with a new one it blew immediately what dies this mean
It means you have a short somewhere downstream from the fuse. The fuse is there to protect the equipment from overloads. Take it to a shop and have them look at it.
May 08, 2015 | Sony Audio Players & Recorders
Do I repair or replace
It depends how much you are ready to pay for the repair? I would ask for an estimate from a repair shop.
May 25, 2013 | Sony Fm Stereo Fm/am Receiver Audio Video...
Why do speakers crackle and flash protect
Check your speaker wires. Make sure they are not touching each outher or back of the unit. This will overload your output transistors and shut down your amp.
Aug 13, 2012 | Sony Str-d565 Digital Audio Video Control...
Hello my sony audio/video control center #STR DE335 is in PROTECT MODE.. and i cant listen to it..can u please tell me whats wrong?
PROTECT display indicates that receiver got serious problem in output amplifier section and protection mode is activated to avoid further damage.
Output amplifier section should be tested by qualified technician to find out and replace defective part(s) to solve this issue. Local repair shop will do this job as it is not user level repair.
Thanks.
Apr 29, 2011 | Sony STR-DE335 Receiver
"PROTECT"flashing, no response, STR-SE391
The audio amplifier IC are fried and need to be replaced
Feb 06, 2009 | Audio Players & Recorders
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
MODEL STR-D565 PROTECT LIGHT FLASHING
Hello!
Your amps' output section is shorted and is sending it's supply voltage straight to the speakers. The protect circuit is there to protect your speakers from being burnt. You need to go to an authorized Sony service center. Good Luck!
barneyluc
Oct 11, 2008 | Sony Audio Players & Recorders
I have a sony digital audio/video control center cinema studio ex and i have no idea how to hook up the surround sound to the tv and dvd player. i have to instructions
i have a Sony digital audio video control center that has a block on it which i can not start my system it reads protecter on it, how do I get it started.
Feb 27, 2008 | Sony Audio Players & Recorders
3,995 people viewed this question
 Grubhead
Grubhead
