Question about Samsung Televison & Video
The yellow Av input Jack has stopped working on my tv so that rather than displaying a clear picture when I hook up my play station 2 it comes up blurred and hard to see. The play station still works on other tbs though so it's a fault with the tv
    Problem Solver:
  • 17 Answers
Either go by an RF modulator that will convert composite visit to coax or replace the main pcb on the set
Posted on Sep 09, 2010
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
Feb 06, 2011 | Computers & Internet
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My screen on my nes is blurry how can i fix that
If your screen shows a blurry image it can be a few possible things (and only these things).
1. The first and most obivous problem is being on the wrong channel - for example, if you are on Channel 3, but the switch on the back of your system is set to channel 4, you'll see a VERY fuzzy picture; simple switch to the other channel and it will come in clear.
2. Now...assuming you are on the correct channel, does your television receive other pictures clearly (for example if you change to a normal broadcasting station and it is still blurry, then it is a problem with your TV and not your NES system). Another way to test is to simply switch TVs and see if the same picture problem occurs.
If 1 and 2 are not the problem, them we know the problem is with your NES system and this should be an easy fix.
If you are using an RF Switch, then it is most likely the pin on either end of the switch has become bent (or was bent and now is bent back) and will no longer give a clear picture. The easiest way to test this is find a set of AV cables (any av cables - these are the red, white, and yellow cables that often hook DVD players to television). Find a set and just take one of those ends and connect it to the side of the NES system into the circle that says VIDEO and take the other end of that same color and put it into your TV into the circle that says VIDEO (note that the colors don't always match up on the newer TVs, just make sure that if you are using the yellow end of the AV cable and plug it into the video on the NES that you plug the other yellow end of the av cable into whatever color on the TV says VIDEO! Then change your tv to the cannel for that AV slot (usually AV 1 or INPUT 1). Turn the nintendo back on and see if the picture comes through clearly - if it does, it means you had a bad RF switch and you can either get a new one, or just use AV cables instead!
One of the above problems IS the problem - I've repaired over 1000 NES systems and 95% of the time it's just a bad RF switch (so the AV cable test works best)
Jan 14, 2010 | Nintendo NES Console
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
Installation
OK THE RED IS POWER
THE BLACK IS GROUND
THE YELLOW IS YOURE AV INPUT
THE ONLY PROBLEM YOU HAVE NO AUDIO INPUTS
ON THIS UNIT
THE YELLOW GOES TO THE YELLOW ON THE PS2 WIRES
Apr 24, 2008 | Legacy Audio LM56 5.6 in. Car Monitor
Televison & Video Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
