Question about Toshiba COPIERS - E-STUDIO 311C Copier
Service problem giving code F11 on estudio 311
    Sniper:
  • 66 Answers
[F11] Communications error between system-CPU and scanner-CPU
This quite often can be cleared up by resetting the machine. If not you will want to check all of the connections between the scanner, the scanner board and the system boards in the back of the machine. If nothing is loose this is likely a very critical error and you will need to have a toshiba authorized technician take a look at your copier.
Posted on Sep 08, 2010
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
How can i get the Nokia Asha 311 Restricted / unlocked code ? Please help me ???
Hi if your Nokia ash 311 phone is asking for restriction code once you insert your sim in it then it mean your phone is locked to some other network provider due to this it wont accept your sim until you unlock .You can purchase restriction code from sites like OnlineGSMUnlock,com for affordable cost ...
Jul 16, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
Formate nokia310
Please always Remember, while doing Master Reset Nokia Asha 311 to factory default, the data will be loose, that's why we can do backup all data or important stuff at Nokia Asha 311.
#Option 1, Hard Reset Nokia Asha 310 & 311 with menu setting:
  1. Make sure the Nokia Asha 311 on and standby
  2. Go to menu Setting, then choose restore factory setting > settings only
  3. It will ask security code, input default security code of Nokia Asha 311 : 12345
#Option 2, Hard Reset Nokia Asha 310 & 311 with special code / master key / shortcut / secret key :
  1. Try to type: *#7370# and it will ask the security code of Nokia Asha 311, press 12345
  2. You also can try type: *#7380#
#Option 3, Soft Reset Nokia Asha 310 & 311 with special key code :
Please take attention, this option is for soft reset, so Nokia Asha 311 will not removing any important data and installed applications. How soft reset Nokia Asha 311 work: It will recopy or restore the default copy of .ini to Nokia Asha 311.
  1. Type in the phone : *#7780#
Jul 31, 2013 | Electronics - Others
Enter restriction code nokia 311
You can get the restriction code for your Nokia Asha 311 from Theunlockspot.com .You need to specify the country,locked network,IMEI number and get the unique unlock code.they also provide free unlock instructions along with the unlock code.
Jun 01, 2013 | Nokia Asha 311 Mobile Phone - Unlocked Red
My kenmore he2 plus keeps giving me an f11 code...I cleaned out the pump and it appears to be working...it fills with eater but does not move at all then pumps the water out ..next it gives me an f11 code
What the F11 means per the Manfactures service manual says "Serial Communaction Error" to put that in simple terms it says the main control board isn't talking to the motor control board. What would need to checked when the F11 code is displayed is for good tight wire connection on all the wiring harnesses between the main and motor control boards, if all the wiring plugs fit tight onto both control board while i hardly advise this and belive in the you can do it byself spirit it , but call for service so the operation of both control boards can be checked to see which on has failed.
Oct 07, 2011 | Kenmore HE2 Plus Front Load Washer
I have a toshiba estudio 2500c. I have error code C3B0. How do I fix it without calling a service person?
I have a toshiba estudio 2040c. I have error code C3B0. How do I fix it without calling a service person?
Sep 08, 2011 | Toshiba E-studio 2500c Color...
Problem with code F11 on Estudio 311c - aspanner
Sep 08, 2010 | Toshiba COPIERS - E-STUDIO 311C Copier
We are getting code F11. What does that mean?
Hello. the F11 trouble code means Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
These are circuit boards within the machine and one of them will have to be replaced. Most folks leave this job up to the service technicians.
Feb 02, 2010 | Kenmore 46462 Front Load Washer
158 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
