Question about Samsung 80GB INTERNAL 3.5- IN SATA HDD 7200RPM 8MB 1- IN HEIGHT 3- YEAR WARR. BULK (SP0802C) Hard Drive
How to change head - Samsung 80GB INTERNAL 3.5- IN SATA HDD 7200RPM 8MB 1- IN HEIGHT 3- YEAR WARR. BULK (SP0802C) Hard Drive
Cannon 8100 - message to do head cleans and if not fixed replace both heads. In service mode test print is fine. Did a head replacement without changing heads and still get the change heads message. Any...
You can try by cleaning your cartridge heads. The best way is to put your cartridge heads in warm water for like 5 mins and the clean the terminals using alcohol swab.
Nov 04, 2013 | Office Equipment & Supplies
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
Changing heads How does the 622 flash change its heads
The flash heads just plug into the unit. You slide off the normal head and slide in a different one. The pins also code the GN changes so the display on the back are consistent with the head used.
Oct 23, 2011 | Sunpak 622 Super Pro TTL Flash
A red warning light is flashing...looks like the razor heads icon...what does this mean??
It's means that you should change new replacement heads, that Norelco RQ10 shaving heads for Norelco Arcitec Electric Shaver heads replacement parts.
Jul 06, 2011 | Norelco Arcitec Electric Shaver -...
The red light showing the shaving head remains on and the shaver discharged the shaver is one year old
Philips suggests changing the heads every 12 months. The indicator is instructing you that it is time to change them. You will find replacements for model 1060x at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Dec 01, 2010 | Philips Arcitec 1060X
One colour, Cyan will not print.
Some nozzle on print head is clodged. Remove the head, on some cloath, spill water and few times press head nozzles on it ( bottom side ), dry it and then do the head cleaning. If dont help change print head, when print head is changed its also recomended to change absorber and purge unit too.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Yelllow wont print,...changed cartage cleaned
If after cleaning the print head and changing the cartridge yellow still doesn't print, it sounds like there may be a problem with the print head or the board that controls the print head. The print head may not be receiving the signal to turn on. Check the circuit boards on the machine for obvious damage or a burn smell. Depending on the model printer it may be cheaper to replace the printer than to have the board or print head replaced.
May 15, 2010 | Epson Stylus 2200 InkJet Photo Printer
Will not print plank pages,even after cleaning.
check print head and head cable............
If ink flow change mainboard, print head, and head cable. if ink not flow change only main board
Jan 06, 2010 | Epson Stylus C84 InkJet Printer
Blown head gasket
I would change both, as well as use new head bolts. Make sure your heads are not warped or cracked, especially the one that is leaking. There may not be any need to change the head if it is not cracked. These are prone to blowing a gasket especially after 150K miles or so. It will not cost a huge additional amount to change both head gaskets since the engine will have to be disassembled down to the heads anyway. Hope this helps you, Rick
Apr 18, 2009 | 1998 Ford Crown Victoria
Change printhead in 5500
To change the printer head on the Kodak 5500 AIO printer, you will need to do the following:
To remove the old printer head,
  1. Power on the printer.
  2. Lift up the lid to expose the printer head.
  3. Once the printer head moves to the middle, where you can get at it, then unplug the power cord to the printer.
  4. Remove the ink cartridges.
  5. With the printer head now empty, run your finder along the underside of the top of the printer head, all the way to the left side of the printer head.
  6. Push up with your finger where there is some give, and the shroud that holds the printer head will release the head.
To install the new head,
  1. Simply put it in place, and push forward with your finger on the sticker that shows a finger pushing on a sticker, and you will hear and feel it click into place.
  2. Reload your ink cartridges, close the lid, plug the printer back in and you're done.
Nov 29, 2008 | Kodak 5500 ALL-IN-ONE PRINTER
Samsung 80GB INTERNAL 3.5- IN SATA HDD 7200RPM 8MB 1- IN HEIGHT 3- YEAR WARR. BULK (SP0802C) Hard Drive Logo
54 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
