Question about Amana Heating & Cooling
I have central air (Amana). Is it common to hear a loud surge sound when the unit comes on. It was installed this summer.
    President:
  • 1,515 Answers
Hi, this surge sound that you are hearing is probably the freon moving through the lines on start up, and if this is a heat-pump and not a gas fired heater you have on this central unit, when the reversing valve is energized in either the cooling mode or the heating mode, you will hear a loud surge of freon gas moving the sleeve in the valve to switch it from one posistion to the other.It is rather loud but should only last for a few seconds or so. If it continues to make this sound after start up, it should still be under warranty, so I would call them out before it expires to be sure its not any thing else. I am sure if you have a heat-pump, and you don't have a gas heater, its just the reversing valve shifting over that is making this surging sound as this is the sound they make. Please keep me posted if it gets worse or you are not sure, and please don't forget to rate me as I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 08, 2010
What causes a condensing unit to run but blower motor will not come on
Most common cause is the capacitor. The top where the wires plug on should be flat. A lightening strike or other power surge will zap it and cause the top to puff up.
Aug 04, 2014 | Heating & Cooling
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
I have an Amana PTAC that was just installed two weeks ago. I am starting hear a moderately loud warbling sound when it is in operation but not all the time. It's loud enough to wake me up in the next...
Is is the sound of water being thrown around? Some units actually sling the water from the drain pan back onto the coil. This improves efficiency. It's sort of a gurgling sound. Here's more helpful information is you need it:
<a href="http://www.ultimateptac.com/ptac-faqs/">PTAC FAQs</a>
Dec 19, 2010 | Heating & Cooling
I live in a condo and have a central air/heating unit in my kitchen/hallway area. This past week, right before it turns on, I hear a very loud bang. It sounds like it is coming from inside the unit. It...
might need to change the filter could be pulling it aganst the frame when turning on hard to say, have it checked out if you are worried it is dangerious.
Aug 30, 2010 | Weather King Heating & Cooling
Central Heat and Air noises.
Hi, It sounds to me that this split system you have is a heat-pump and not a gas fire air handler. The noise that you are hearing must be the freon in the copper lines equalizing in the system upon shut down of the compressor. All systems must and will go through this sequence. It shouldn't be that loud though. The copper lines should have armor flex on at least the larger suction line for insulation and to keep it from condensating everywhere in the summer in the cooling mode.If you find it is bare with nothing on it, you can buy this insulated tubing at Home Depot or O.S.Hardware. Its black in color and is split down the entire 10' section with glue covered seams on it. This should cut down the noise. Depending on the unit size Tonnage wise, the suction line may be 3/4" or 5/8" in diameter.Just ask for there water line insulation and like I said it comes in 10' sections and is very cheap, 20cents a foot or so. Please keep me posted if this does not take care of the problem. It may be coming from the lines where they enter the air handler. I will wait for you're reply.
Sincerely,
Shastalaker7
Jan 21, 2010 | Heating & Cooling
My Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Dec 05, 2009 | Heating & Cooling
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Problem with amana central air conditioner saftey switch
The switch he jumped out was the high pressure cut out switch which tripped because you left the cover on. Sounds as though it did it's job and he cut it out to sell you another. Yes it is important to have as it protects the compressor.
May 05, 2009 | Amana PTC153B35AJ Air Conditioner
Amana Air Conditioning Unit
check your wiring on your t-stat maybe yellow and red touching, how old this house
Aug 17, 2008 | Amana PTC153B35AE Air Conditioner
Heating & Cooling Logo
265 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
