Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Chasis intruded ,after changing cmos battery also the sameproblem
    Scholar:
  • 95 Answers
Either jumper the chassis intrusion header on the motherboard with a striaght jumper(like you'd find on a hard drive), or, easier, somewhere in the bios setup you can set Chassis Intrusion detection or reporting to disable.
Posted on Sep 08, 2010
Cmos checksum bad Chassis Intruded Fatal Error System Halted!
To remove CMOS Checksum error, you have to remove the coin cell battery from the motherboard and install a fresh one. A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For Chasis Intrusion msg, go to the BIOS (when prompted, press the Function Key at the system startup) and locate the option of chasis intrusion option and disable it, save settings. Commonly, to enter the BIOS you have to press F2, F10 or DEL Key, depending up the make/ model of the PC you have.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 08, 2011 | Computers & Internet
Chasis intruded.. fatal error.. system halted!
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
Hope this helps
Jun 03, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My motherboard is asus P5KPL-AM SE when i on it...it detects the hardrives but the lower part was have this msg...."chassis intruded! and system halted! but when i clear the cmos by removing the...
theres many possibilities.... first check if loose connection of cables... also if it helps you might have to jumper hdd ...
and also try replacing cmos battery lastly make sure the chassis sensor button is pressed down when closin lid...
May 21, 2017 | ASUS P4P800-MX Motherboard
I do have a ASUS P5GC-MX/1333 REV. 3.05G Motherboard. Whenever I boot my computer it displays "Chasis Intruded" or "CMOS settings"..............and computer won't boot. after this when...
there are two jumpers side by side. one has 3 pins with same distance between them (for cmos)
and
the other one that has also 3 pings but 1 of them a little bit far from the other 2 (Chasis Intruded)
For cmos,
pin 1 pin2 conected is normal operation
pin 2 pin3 conected is for resetting the bios
if reset caried on jumper must be taken back to normal operation positing
Chasis Intruded worning is shown when chasis jumper removed or put on the pin1 so the jumper can not contact the pin2 and pin3.
You must connect pin2 and pin3 by a jumper and restart your computer. That is al.
Oct 26, 2010 | ASUS Computers & Internet
I do have a ASUS P5GC-MX/1333 REV. 3.05G Motherboard. Whenever I boot my computer it displays "Chasis Intruded" or "CMOS settings"..............and computer won't boot. How can I solve this
> chassis instrusion
Some computers can sense when some (presumably "unauthorized") person removed one of the side-panels from the computer-case, maybe to remove a disk-drive, remove a CD-drive, or remove a stick of RAM. So, your computer is just telling you that it has (sometime) sensed that physical access.
> CMOS settings
What's the _FULL_ text of that message?
It could be that the battery on the motherboard (silver-coloured, about the size of a US $0.25 coin) is "dead", and needs to be replaced.
Oct 25, 2010 | Computers & Internet
When i open computer this massge fatal error chasis intruded
Your PC has a chasis intrusion detection chip installed.
This is common with most business class PC's.
Simply replacing the cover or defeating the chasis intrusion switch will remove the problem. Most people tape the button down if they leave their cases open.
Aug 30, 2010 | Computers & Internet
Chassis Intruded
try take out the battery on board for one min. then put in battery see if that works jim
Feb 16, 2010 | ASUS K8N Motherboard
Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
Nov 26, 2008 | ASUS P5P800S Motherboard
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
183 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
