Question about Konica Minolta bizhub C250 All-In-One Laser Printer
I am new to the bizhub C250 and when scanning a document it puts the scan doc to a file that we have created on our server called "Scanned Documents" However it always saves the scan doc with its own file name how do I scan to a specific file name or folder it this possible. Easy directions please. cheers
  • 1,110 Answers
When you press the scan button and get the screen where you are selecting the location to send to there is a tab at the lower right corner called "scan settings". You touch that, then on the next screen there is a small tab at the bottom center called "file name". Touch that and you can change the file name from the default KMBS...... to whatever you want.
Thank You for using Fixya! and please provide positive feedback if I was helpful.
Posted on Sep 08, 2010
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
How do i set up a scan box on my konica, i have my i.p address already konica minolta bizhub c252
How to setup scan to hard drive on a c250 with standard controller:
1. Enter the ip address in your web browser.
2. Click on the file tab and then the create box under the mailboxes.
3. Input a mailbox number and password that you select in the proper fields.
4. Click on create and after the browser returns to the previous screen you can create another mailbox or log out.
5. After all mailboxes have been created you click on the scan tab to set up a one-touch key.
6. Select the index number you wish to set the one touch key under and then click on an open box. (box with --- In it).
7. On the destination screen that opens select scan to hdd and click on the next box.
8. Name the mailbox with the name you want on the machine display in the destination name field.
9. Select the mailbox name or number for the location using the drop down menu.
10. Click on create to finish creating the mailbox and making it available as a one touch key.
Nov 02, 2009 | Konica Minolta bizhub C250 All-In-One...
I'm trying to use the scanner to scan some documents and store it in a folder in the computer. Can you help me with this? Ray
Your software will usually ask where you want to store the document once it's scanned. A lot of software is intuative enough to guide you through each step.
Aug 19, 2009 | Office Equipment & Supplies
Bizhub C250 How to set scan to multi page TIFF for everyone. How to scan front and back of documents Thanks
To set scan default:
Select Scan Mode
Press Scan Settings
Press File Type
Press TIFF
Press Multipage
Press Ok
Press Utility/Counter
Press User Setting
Press Initial Setting
Press Current Setting
Press Ok
Press Reset
This will only affect address book destinations. Program destinations specify within their settings the file type.
To scan front and back:
Select Scan Mode
Select Destination (must be done 1st!)
Press Scan Settings
Press Simplex Duplex
Press 2 Sided
Press Ok
Mar 27, 2009 | Konica Minolta bizhub C250 All-In-One...
Scanning large documents to PDF takes a long time
Try to use Compact PDF or a lower resolution.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Ricoh MPC 2500 won't scan?
do you have a smtp server? check the smtp server in the usertools, systemsettings, file transfer and smtp server
Jan 07, 2009 | Konica Minolta bizhub C250 All-In-One...
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
E-mailing scanned documents - step by step
Has your MFP been setup to scan to email?
It will require a valid email address and the server settings entered into the Network configuration.
DL the manual:
http://help.bt.konicaminolta.ca
Once configured it is a simple matter of entering the email address and pushing "scan".
Aug 24, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Merging attachments of scanned files sent by email
You can use the IP Scanner software to scan the documents from your Bizhub to your pc. Once the documents are in your PC you can take apart which pages you want from the scanned documents and save them to another file and e-mail them through your computer that way.
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
259 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
