Question about Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
Replaced ao smith mtr with ge marathon, now have leak?from bottom
    President:
  • Sta Rite Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Check the volute o-ring for damage. It sometimes moves as you re-tighten the band around the pump halves and gets pinched. If it was, replace it. You may also need to replace the pump seal and insert if the pump is old enough to have had one. Whenever you change a motor you should also replace the seal.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 08, 2010
Water was pouring out the top of my hot water tank and I would like to know can it be repaired at a affordable price or if it need to be replaced will it be affordable it is a Master Plumber Reliance 501...
Unit is probably rusted out:
http://waterheatertimer.org/Leaking-water-heater.html
Reliance is AO Smith. I recommend the AO Smith line-up of water heater brands as best because air intake screen is located on bottom of unit and can be cleaned by homeowner without removing combustion parts, and because AO Smith posts service manuals.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://hometips.me/Mar/WaterHeaterSerialNumberDecoder.pdf
Add a comment with more detail about leak.
Mar 18, 2013 | Water Heaters
Dead motor on shopcool model# sc3500 are repklacement motors availiale
This unit was made by AdobeAir in Phoenix which has gone out of business. You're in the same boat as all the people looking for replacement motors for their MasterCool MMB10 MMB12 and MMB14's.
You can try to have the motor rebuilt at a motor repair place but I have no idea as to the cost.
I posted this to another question regarding the MasterCool units.
Unless you can find an HVAC shop with a NOS motor for this unit you will not find a drop in replacement. Even if you do get lucky and find a NOS motor be prepared to pay nearly as much for it as you would a whole new evap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It's still a little spendy, especially if you want two speeds like the original motor had, but you can get out for $80 or less if you're willing to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basically what you're looking for is a "48 frame", 1/8 hp, direct drive, 110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to give you flexability when mounting), "totally enclosed" or "open drip-proof" housing (NOT "open"). Rotation can be either CW or CCW as you can mount the motor on either side of the housing and some motors are reversable. If you've got the skill to custom make some mounts then you can probably fudge some of these specs. The ones you can't change are the 1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assembly simply can't be made to go much faster in that housing and if you try you will overheat the motor and burn it out very quickly (trust me on this one!). Most of the cheap motors I've found are 208-230v and I just don't see the point in having a small 220v PORTABLE evap cooler, that's just dumb.
After a LOT of online research I've found the following motors that would be a suitable replacement, with all the above mentioned specifications. I'm sure there are more, but cross referencing this information for someone not in the business is tricky and time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
I suppose that if you found a smoking deal on eBay for an "Open" type motor you could try it, but I doubt it would last long and make damn sure that ****** is grounded well.
Jul 29, 2010 | AdobeAir Mobile Swamp Evaporative Air...
Motor is frozen.
Unlessyou can find an HVAC shop with a NOS motor for this unit you will notfind a drop in replacement. Even if you do get lucky and find a NOSmotor be prepared to pay nearly as much for it as you would a whole newevap cooler.
It'sstill a little spendy, especially if you want two speeds like theoriginal motor had, but you can get out for $80 or less if you'rewilling to settle for one speed (on/off).
Basicallywhat you're looking for is a "48 frame", 1/8 hp, direct drive,110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to giveyou flexability when mounting), "totally enclosed" or "open drip-proof"housing (NOT "open"). Rotation can be either CW or CCW as you can mountthe motor on either side of the housing and some motors are reversable.If you've got the skill to custom make some mounts then you canprobably fudge some of these specs. The ones you can't change are the1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assemblysimply can't be made to go much faster in that housing and if you tryyou will overheat the motor and burn it out very quickly (trust me onthis one!). Most of the cheap motors I've found are 208-230v and I justdon't see the point in having a small 220v PORTABLE evap cooler, that'sjust dumb.
After a LOT of online research I've found thefollowing motors that would be a suitable replacement, with all theabove mentioned specifications. I'm sure there are more, but crossreferencing this information for someone not in the business is trickyand time consuming.
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Isuppose that if you found a smoking deal on eBay for an "Open" typemotor you could try it, but I doubt it would last long and make damnsure that ****** is grounded well.
Jul 17, 2010 | AdobeAir Evaporative Cooler Direct Drive
I need a 1/8hp 115v 1075 2sp swamp cooler motor
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Jul 06, 2010 | AdobeAir Mobile Swamp Evaporative Air...
The motor has burned out. I need a replacement. Where can I get a new motor?
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Jul 05, 2010 | Cfm 2000 Swamp Air Cooler MMB10 MasterCool...
Have a master cool MMB10 and all of a sudden the fan runs slower on both speeds. Motor bad or something else?
Mine did that too. Either the motor needs to be cleaned out or the motor is shot. You can try to have the motor repaired. If that fails a replacement motor is about $120 if you can find one.
I posted this to another solution for someone looking for the motor:
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Jul 04, 2010 | Mastercool Portable Air Conditioner
Need replacement motor for a model MMB10B
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Aug 07, 2009 | Mastercool Portable Air Conditioner
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
105 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
