Question about Sony VPL CX10 Multimedia Projector
I get a 'no signal' message when I connect my laptop, I have tried several different cables but the same problem
  • 22 Answers
Try going into the display settings on your laptop and turn on projector or external display.
Posted on Sep 08, 2010
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
ERROR MESSAGE NO SIGNAL INPUT
What is your TV signal source? Press the Input button on the remote and try another input. (Make sure a DVD player or set-top box is on.) If you are on the TV input, try a different channel. Next make sure that your cables are securely connected to the TV and devices. Replace with new cables to test them. If you use an OTA antenna with a splitter, try a direct connection. (Similarly, if you have an amplifier on the signal, try a connection without the amplifier.)
For OTA or direct cable connections, try accessing the Channel Setup menu and rescanning for channels.
I hope this helps.
(I get some weak channels that give No Signal messages when the transmitter has a problem or the weather is bad. I've also had a signal splitter/amplifier fail and block specific channels by becoming a filter. The direct connection identified the amplifier problem.)
Mar 06, 2013 | Sony KDL-40VE5 40" HDTV LCD TV
My flat screen says no signal when i try to watch a movie from my laptop, what do i do?
Hello Nabrowne Hi, Use the input selector on the TV menu, if still no success try a different cable for your flat screen. there are several input you can use, the common one is the VGA, and the sVideo. connect the VGA cable to the TV. then on the menu select VGA/PC then on the laptop find the Fn functions that send the signal to the TV.
Jan 03, 2011 | Computers & Internet
My xbox cuts on abut wont connect
I'm thinking bad AV cable or bad port on your TV. I assume the Xbox dash board won't come up, if so the "no signal" message is a TV error message not an Xbox error message.
Try a different port on the TV and/or a different TV; also try a different AV cable.
Good luck. Please rate, thanks.
Mar 05, 2010 | Microsoft Xbox 360 Console
I show on monitor "no signal" Check Signal Cable
Check that the "data" cable between your computer and your monitor is tightly connected at each end.
Connect the VGA-output port from a laptop computer to the monitor, to see if the monitor works when connected to a different computer.
Connect a different monitor to the VGA-output port on your computer, to see if that monitor works.
Failing all the above, the video-card on your computer is the problem, and needs to be replaced.
Nov 05, 2009 | E-Machines (T3104) PC Desktop
No signal projector (TLP-S71)message connect to laptop
make sure the cable is good. then make sure the resolution matches.
Jul 28, 2009 | Toshiba TLP S30 Multimedia Projector
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
Card is green, wireless router is green , but no internet
r u c'in any message as limited r no connectivity in wireless connection,did u chk if u r able to go online wth the cable connection in ur laptop
Nov 05, 2008 | Dynex 802.11g Wireless-G Laptop Card
Bad connection between laptop and lcd projector
First, check all plugs and make sure there are no broken or bent pins in them. If the projector you are using have a replacable cable try to replace it to see if the cable is the problem. (borrow a cable from a friend or relative first so you don't buy one if it is not needed.)
If that doesn't fix it, try to connect a different computer to your projector to see if that is better. If so, the output port on your computer may be bad.
Also try to hook your compuber to a different monitor to see if that works. If no computers are able to make a good picture on your monitor, the monitor is at fault.
The fact that you can change the picture quality by wiggling the cable, and that it starts to search for a signal suggests that the cable or the plugs are at fault, but having the wrong resolution set up on your computer may also affect the image quality. Again, try to use a different computer as a source to eliminate (or confirm) your computer being the problem.
Feb 19, 2008 | Compaq Presario 2140US Notebook
Sony VPL CX10 Multimedia Projector Logo
71 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
