Question about Bowflex Exercise & Fitness
I have a TC5000 (purchased in july 2005) and the drive belt split. I purchased a replacement belt and when I went to install it I noticed that the motor unit and the pulley unit are not alligned and as a result of this the new belt works it's way off the drive motor until only the last 2 or 3 groves of the belt are still engaged. Is there a way to get the pulley and drive motor's aligned so that the drive belt does not walk off the drive motor?
SOURCE: I have a problem with
You can download the User's Manual as a PDF file for free:
http://www.fitnessequipmentcatalog.com/lifestyler-owners-assembly-manual.htm
A complete parts list is included in the manual.
Posted on Apr 09, 2008
SOURCE: Serpentine belt in a 1995 Mercury sable
I have the same car and last night my belt slipped off. The top small pulley backed it's self out. The problem is in most cars the pulleys are reverse threaded so this wont happen, in ours not so much. The pully spins loose with the turn of the belt so it has to be tightened way down. IT's a pain. Here is a diagram I found and You need a 15mm wrench, which doesn't just come in most sets. Good Luck
The book says "Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise. Make sure spring keeper engages into slot." I would put a socket on the 15 mm pulley bolt and a long handle for leverage. Thats one tight spring.
Posted on Nov 06, 2008
SOURCE: drive belt loss
i had the same problem, i even took it to the dealer and they couldn't fix it. After a while I finally figured out that the belt tensioner was slightly bent down. I straightened it out and I haven't had a problem since. I hope this helps
Posted on Apr 03, 2009
SOURCE: I'm having a problem re-fitting the drive belt to
After some mild swearing, I made sure that I had the belt around the drum aligned (in the same plane) as closely as I could with the drive pulley and tensioning wheel. I think this was partially achieved by placing the belt as close to that position as possible before lining up the front end of the drum with the cabinet opening, and then turning the drum from the front (through the open door) very slowly clockwise (the direction of its normal rotation) to give the belt "time" to align itself fully with the smaller pulleys. A short prayer and a few minutes later, the machine was humming away with all parts playing their "part" in beautiful harmony - without the dreaded sound of a thin black drive belt cluncking to the floor of the metal cabinet.
Cheers,
Andy B.
Posted on May 02, 2009
  • 86 Answers
SOURCE: belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
Posted on May 16, 2009
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
I would like instructions on changing a water pump in 2005 Chevy uplander V6 3900
This is probably the easiest water pump of all vehicles to change.
Water Pump Replacement
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  1. Remove the water pump bolts, pump, and gasket.
  2. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump (1).
Notice: Refer to Fastener Notice in Service Precautions.
  1. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolt until snug.
  2. Install the drive belt
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 ft. lbs.) .
  1. Fill the cooling system
  2. Inspect for leaks.
Aug 18, 2013 | Cars & Trucks
My Sonata GL is at 105K; in the maintenance schedule it is recommended to replace the timing belt. 1) If this particular belt breaks what would be the damage? 2) How much leeway do I have, eg.:100 miles,...
Timing belts are typically only used on overhead camshaft engines. Timing belts are used to synchronize the crankshaft with the camshaft, similar to a timing chain on an overhead valve (pushrod) engine. Unlike a timing belt, a timing chain will normally last the life of the engine without needing service or replacement. Timing belts use raised teeth to mesh with sprockets to operate the valvetrain of an overhead camshaft engine.
Whenever a vehicle with an unknown service history comes into your repair facility or is recently purchased, here are some points that should be asked to help prevent costly engine damage:
* Does the owner know if, or when the belt was replaced-
* If the vehicle purchased is used, or the condition and mileage of the last timing belt replacement are unknown, it is recommended to inspect, replace or at least inform the owner that the vehicle is equipped with a timing belt.
* Note the mileage of the vehicle. The average replacement interval for a timing belt is approximately 60,000 miles (96,000 km).
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
1. Raise and support the vehicle.
2. Remove the engine splash shield.
3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
4. Remove the drive belt from the alternator.
5. Slowly release the drive belt tensioner.
6. Remove the drive belt from the accessory drive pulleys.
Fig. Accessory drive belt routing - 2.4L engines
To install:
1. Install the drive belt to the accessory drive pulley.
2. Rotate the drive belt tensioner clockwise.
3. Install the drive belt to the alternator.
4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
6. Install the engine splash shield.
7. Lower the vehicle.
Hope helps.
Dec 22, 2010 | 2005 Hyundai Sonata
We canNOT get the belt on the new treadclimber - there's no give and it's just not going
Can you describe your machine type (TC5000, for example) and what you've done to try and reposition the belt? Also which belt are you referring to? The treadle belt or the motor belt? I just went through a complete deck/walking belt replacement, and it's not for the faint of heart. Needed to dismantle almost 85% of the machine.
Aug 28, 2010 | Bowflex Treadclimber
Change the alternator
2005 Pontiac Vibe FWD L4-1.8L VIN 8
Alternator: Service and Repair
Generator Replacement
GENERATOR REPLACEMENT
REMOVAL PROCEDURE
CAUTION:
- Refer to Battery Disconnect Caution in Service Precautions.
- Failure to observe step 1 may result in a serious personal injury. If a tool is shorted at the generator lead, the tool will become hot
enough to cause a serious burn.
1. Disconnect the negative (-) battery cable.
2. Loosen the belt tension by turning the drive belt tensioner clockwise.
4. Disconnect the wire clamp (3) from the wire clip.
5. Remove the terminal cap and nut (1).
6. Disconnect the engine wire.
7. Disconnect the generator connector (2).
8. Remove the two mounting bolts.
9. Remove the generator (4).
INSTALLATION PROCEDURE
1. Install the generator (4) to the vehicle.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Secure the generator with the two generator mounting bolts.
Tighten
- Tighten the upper bolt to 25 N.m (18 lb ft).
- Tighten the lower bolt to 54 N.m (40 lb ft).
3. Connect the generator connector (2).
4. Connect engine wire to the generator.
5. Secure the engine wire with the nut.
Tighten
Tighten the nut to 9.8 N.m (86 lb in).
6. Install the terminal cap (1) to the nut.
7. Install the wire clamp (3) to the wire clip.
8. Install the drive belt.
- Visually inspect the drive belt for wear and damage.
- Minor cracks on the ribbed side of the belt are considered acceptable. Replace the belt if pieces are missing from the ribs.
- Ensure that the belt tensioner moves downward when the belt is pressed down in the center with a force of approximately 98 N (22 lb).
9. Connect the negative (-) battery cable.
Tighten
Tighten the bolt to 15 N.m (11 lb ft).
Sep 06, 2009 | 2005 Pontiac Vibe
The brushes aren't spinning
The brushes are belt drive by a belt. The belt is probably broken. You can purchase a new belt at a local discount store and replace it. You won't find anything that looks like a pulley, it'll just be a bare round metal portion of the brush assembly that is located at one end. The motor end will look similar.
Feb 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Engine whinning
I had the same problem on my 2005 Envoy. Turned out to be the idler pulley bearing. It is just a pulley the belt rides on. The bearing in the pulley was what was making the high pitched whine. I replaced the bearing, and the noise went away.
Jan 12, 2009 | 2005 GMC Envoy
Exercise & Fitness Logo
23 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
