Question about Hotpoint WF430 Front Load Washer
My washing machine isnt spinning or pumping water out? what could be the cause?
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 08, 2010
Fisher and paykel washing machine top loader doesnt spin dry the clothes well. There isnt any water in the machine after the spin cycle but the clothes are heavy wet. What's could cause this?
Machine not spinning. Have you stood next to machine and listened? When all water is drained out (watch the drain hose for water to stop) then you should hear the spin start and hear it building up speed. If it doesn't then you need to post back here with more detail on what you could hear or see happening. i.e. how long after water stopped draining did machine finish and switch off?
Nov 05, 2016 | Fisher and Paykel Washing Machines
Spin cycle isnt working.."OE" is pn display
Error code OE on The LG washing machines simply means the pump is blocked.
Presumably the water isn't being emptied properly you might have something blocking the pump.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out.
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose near the sink waste or somewhere else in the system etc.
Sep 13, 2015 | Washing Machines
My zanussi zwg6141p wont spin and cut out during wash?
replace the carbon motor brushes and retry if it wont spin usually the water isnt taken out fast enought to satisfy the vaccume switch so its the pump the switch or an air lock
so empty the machine totally and expell all water from all hozes and check the waiste is aok for flow no jams your left with either the pump motor issues bits of b.a wires or the main motor brushes
Mar 05, 2015 | Zanussi Washing Machines
Door does not unlock after spin
so the machines isnt detecting water has all left
so vaccum switch
or door interlock isnt good
clean the pump and check its housing for cracks
check your waist can cope with flow
then replace the interlock first
then the pump
so interlock then pump
Mar 05, 2015 | Washing Machines
My washing machine isnt loading with water
hi i think you mean a ball looks like a ping pong ball it doesent go in pump it sits in filter i allways take them out anyway its up to you strange about water check wires to valves were water pipes fit unplug 1st
Jan 12, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Machine will not spin or drain
good day?
fully automatic machine? washing cycle is normal?
if yes, do the same.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Whirlpool Washing Machines
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
Nov 02, 2013 | Washing Machines
Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
Oct 31, 2011 | GE Washing Machines
Samsung washing machine WA71N2
can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Mar 07, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Sep 12, 2007 | Kenmore 22422 Top Load Washer
Hotpoint WF430 Front Load Washer Logo
114 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
