Question about Dishwashers
Moved into house with Thor PLS602 dishwasher but cannot figure out how to use it. It doesn't appear to have a place to put the dishwashing tablets.
    New Friend:
According to another thread, pour some dishwasher powder, or liquid into the circle on the back of the door.
Posted on Sep 18, 2013
Noggin
  • 944 Answers
SOURCE: roper dishwasher
Here is the link to the user manual if you need it; http://www.roperappliances.com/data/8575997.pdf Page 17 gives all the numbers to call for replacement front panels. here is the link to the installation manual; http://www.roperappliances.com/data/3385181.pdf Page 13 onwards tells you all you need to change the panel. Hope this helps :)
Posted on Mar 19, 2007
SOURCE: hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Posted on Dec 23, 2007
  • 6 Answers
SOURCE: dishwasher powder/tablet not being used
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Posted on Mar 07, 2008
SOURCE: GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Posted on Jun 18, 2008
  • 1462 Answers
SOURCE: dishwasher
have only worked on them a few times but no problem to use. literally select program, close door and start. you won't break anything by trying it out.
put detergent in the dispensor and rinse aid in the rinseaidv despensor. if in a harrd water area, add dishwasher salt to the softener
Posted on Aug 21, 2008
Dishwasher leaking from pump housing.
If it is not leaking around a shaft seal, you can disassemble it again and use permatex or silicon sealer on the mating surfaces
May 03, 2013 | Frigidaire Professional Series 24 in....
Rinse Aid Quiet Partner 1
Just unscrew the little (blue?) cap next to the detergent container.
Aug 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
I have just moved into a new house with what looks like quite an old ADG7540 dishwasher. The detergent dispenser doesn't open during the cycle - even though I have cleaned it. There also doesn't appear to...
Hi jo..... many of the old dishwashers did not have an upper arm. Regarding the detergent dispenser there are a couple of reasons why it no longer operates but rather than spend money on a repair I recommend that you simply purchase the 3 in 1 tablets and toss one right into the floor of the dishwasher and turn it on. That said, always run the hot tap water into the kitchen sink until it is as hot as it will get BEFORE turning on your dishwasher.
AND since this is an older model always rinse any food or debris from the dishes before placing them into the machine. Joe
Thanks for choosing Fixya!
Dec 04, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Accidentally put normal dishwashing liquid in the rinse aid space
The amount you have put in although not good is not too serious.You can try putting nothing in dispenser for a few washes and see how that goes.If you are using the 3 or 4 in one tablets you should not need to dose with rinse aid or salt as it is in the tablets.
Hope that helps.
May 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
What kind of dish soap do you use and where do you put it?
Any dish washer soap powder. Refer to the manual.
Mostly if you open the door you will find a small plastic type box for the soap powder.
Unable to find ! Do not worry. Put it in a small lid and place it. The water jet will do the rest!!
Mar 29, 2010 | Equator 20 in. PLS602 Free-Standing...
I have a GE PDW8680 dishwasher. 5 1/2 years old.
sadly when doing DIY repairs you must be able to figure out how to remove and replace the parts. you could search youtube for a video
Oct 16, 2017 | GE 24 in. Profile PDW8680JSS Built-in...
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
Dishwasher is leaking water. Water is puddling
There is a tube on the side of your dishwasher for over flow. It sounds to me like your washer was moved and it banged against that line. You can put some caulking around where it enters the washer and that should be fine. The bottom can be several things. If your washer was removed and reinstalled like say maybe floor installation the supply line, or waste line may not be tight. If your unit has not been moved recently it is most likely the motor housing. Take off the one or two covers on the front bottom of the washer. Place the washer through the cycles and with a flashlight see at what cycle and where the water is coming from. It it appears to be coming from the white housing it's the motor. It's cheaper to just replace the unit as these motor housings are around $150.00. Check out craigslist. Hope this helps.
JimmyC
Sep 25, 2009 | GE Dishwashers
Dishwashers Logo
142 people viewed this question
Top Dishwashers Experts
