Question about Toshiba Satellite A205-S4777 Notebook
I have Toshiba Satellite A205-S4777, laptop, I am facing startup issue. When powered ON only with Battery without AC suppy it boots correctly. Once Booted completly if AC power is connected, then mouse does not move PC hangs. With AC power it never boots. PLease suggest the solution to resolve the issue.
    Problem Solver:
  • 5 Answers
Solutions :- Toshiba Satellite
THIS IS BECAUSE OF MOTHERBOARD PROBLEM, U NEED TO REPLACE CAPACITOR PACK WHICH IS AVILABLE BOTTOM OF MBD
thanks...........
find me on google :- LAPNOSYS.in
Chip Level Motherboard Expert
Posted on Jan 04, 2013
    Problem Solver:
  • 10 Answers
There may be a problem with ur power adaptor or ur battery charging section
Posted on Sep 08, 2010
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
Hi. I have a Toshiba laptop a205 s5812. The problem is when I start it with AC adaptor connected it wont start. If I start it without connecting the adaptor it works fine, but once on if I connect the...
Although this may only be a temporary solution, try connecting the adapter but taking the battery out. Now try turning on the laptop. It should work. Unfortunately, this means that you will need to always connect the laptop to the wall when you want to use it.
Mar 21, 2011 | Toshiba Satellite A205-S4777 Notebook
I have a toshiba LT a205; the LED flashes 6x; what does that mean? the psu is rated at 19vdc, and puts out 18.5 vdc. The end of the power connector that goes to the mb only has 0.5 vdc on it, so I'm...
19volts is a nominal value. The AC Adapter will be fine from 18 volts up to 20volts because the power unit on the motherboard regulates the voltages very accurately.
You say you only have 0,5volts on the Mother Board power input. There's your fault. Between the Mother Board socket and the AC Adapter.
Replace the AC Adapter or Laptop Connection lead if you mean there is 0.5volts actually on the Mother Board but full oiutput from the Adapter.
Dec 15, 2010 | Toshiba Satellite A205-S4777 Notebook
When i plug in my toshibba satellite a205, the plug light turns on, but the batery charge lights flashes just once, then goes off. my battery says 2%, not charging. is it a battery or combination laptop...
True turning it on while pluged in but without the battery in. If it works its your battery if not it is you charger or laptop, my bet is on the charger they have a tendancy to go out.
Feb 14, 2010 | Toshiba Satellite A205-S4777 Notebook
Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 06, 2009 | Computers & Internet
Can't boot up
Hi!
You must have got a recovery disk with your laptop, insert that disk and it will solve your issue. If you are unable to find the disk or if that disk doesn't help then you will need to re-install the windows on your Toshiba notebook.
Please ask for any clarifications.
Do rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 16, 2009 | Toshiba Satellite A205-S4777 Notebook
Problem with booting my A205-S4577 with the powercord on
Have you tried a new power AC/DC convertor ? make sure you have the correct spec...see manual for power adaptor needed. Cost less if you can get a loan of one. other than this i would be looking into checking the power jack. hope this helps
Feb 15, 2009 | Toshiba Satellite A205-S4617 Notebook
CAN I NCHANGE MY OS VISTA TO XP ??
before changing plz check the availability of the drivers
Feb 02, 2009 | Toshiba Satellite A205-S4777 Notebook
My Toshiba A205 S4777 won't start up and I can't use the recovery media to fix it.
Try flashing the bios by pulling the chord out attached to the "watch" battery.
Oct 12, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4777 Camera help
sounds like the camera wires are broken. you would have to take apart the screen portion of the laptop to see if it is connected still. you would then have to splice the wires together if they are broken/damaged
May 23, 2008 | Toshiba Computers & Internet
Toshiba Satellite A205-S4777 Notebook Logo
300 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
