Using Vista Home Premium, I am recieving the following error message: "network adapter microsoft isatap adapter #2 windows cannot load driver (code 31)" i have also uninstalled it and is not able to get its drivers where to get its drivers from?
    President:
  • 2,571 Answers
Check this forum out, looks like that adapter is not needed http://www.vistax64.com/vista-networking-sharing/30771-microsoft-isatap-adapter.html
Posted on Sep 08, 2010
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
Microsoft ISATAP adapter is not working
You're definitely not the only person with this error. You didn't supply us with too much information but a common cause for this problem happens when you do a Windows update. It will update your computers wireless network card drivers with incompatible drivers. Try rolling back your network card drivers by following these instructions.
Roll Back Drivers
Don't worry about the warnings Windows gives you, if all else fails you just hit the Update Drivers button and go back to default settings.
P.S. If this doesn't work, we will need more info on your computers hardware. Try to find out which network cards you are using and post them here.
Jul 29, 2011 | Microsoft Windows 7 Home Premium 64BIT...
In Device Manager, under Network Adapters I find a new entry called "Microsoft ISATAP Adapter".The yellow explanation mark indicating a problem is present. Status shows "Windows is unable...
Hi.
Let me explain you about the Microsoft ISATAP Adapters.
ISATAP (Intra-Site Automatic Tunnel Addressing Protocol) is an IPv6 transition mechanism meant to transmit IPv6packets between dual-stack nodes on top of an IPv4 network.
It is a Windows Operating System Generic Driver.
This Driver will be installed automatically.
As this is a Windows default Driver, it has no specific functions.
As you are able to view the "yellow exclamation mark", you may just un-install the Driver..
This should not change the functionality of the Computer.
1) Right-click on the "ISATAP Adapter" in the Device Manager. 2) Then, click on "Un-install". 3) This should un-install the Driver. 4) Once you have done the above steps, restart the Computer for the settings to be enabled.
Performing the above steps should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 23, 2010 | HP Pavilion dv6000z Notebook
Cannot connect to wireless
Hi, reinstall the latest adapter drives.
Aug 01, 2009 | Computers & Internet
Unable to connect to the internet at times.
Problem #1:
Please give more details about your setup -
  • What kind of router are you using (make. model, version)?
  • Do you have a wired or wireless connection from your computer to your router?
  • By "resetting" do you mean to "repair" the connection via the taskbar?
Problem#2:
This is apparently a well-known bug in Vista, but nothing to worry about. Take a look at the information from Microsoft.
Please give more details regarding problem #1 and I'm happy to see if I can be of any help.
Jun 10, 2009 | Computers & Internet
I have windows vista home premium on my home computer and have been experiencing some internet disruptions. The only two ways I have found to reset the internet connection is (1) unplug my router and then...
In the Control Panel, update the drivers. If still unsuccessful, delete those adapters, restart your workstation and reinstall drivers. Helpful to have another workstation nearby in case you need to download the drivers from the Internet.
ISATAP Adapter #26 not installed
http://www.soft32.com/download_175416.html
This is kinda Microsoft. See if you can dig around here for your version if this doesn't work. Good luck, and rate, if helpful of course.
Jun 01, 2009 | Microsoft Windows Vista Home Premium with...
I have a problem with Microsoft ISATAP Adapter #3 driver
yes maybe its inside the computer or download a fresh driver
Feb 01, 2009 | Microsoft Windows Vista Home Premium with...
EXCLAMATION MARK IN THE DEVICE MANAGER
Regarding the Microsoft ISATAP Adapter error, you can ignore it safely. Please refer to the following link:
http://support.microsoft.com/kb/932520/en-us
Dec 07, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
309 people viewed this question
David Payne
David Payne
