I am getting power surge problem in my dell inspiron 600m laptop. please tell me how to resolve this problem
  • 1,472 Answers
Raja_mamidi
If you are get a power surge most likely there is a problem with the AC Adapter and you will want to get it replaced.
I would recommend that you call Dell directly at 1-800-WWW-DELL to order a replacement if you are out of warranty.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 08, 2010
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
I have a dell inspiron (600m) andi also have a dell flat screen television. i used to be able to connect my laptop and tv, so the tv would become a flatscreen. i would go to VGA and my laptop would appear....
I assume you would switch the TV's source to VGA. Is that correct?
Connect it the same way you did before, with the VGA cable. Then hit Fn + F8 on your keyboard, to switch the signal from your laptop screen to the VGA cable. Then select VGA as your source on your TV as you did before.
If that does not work, please post and tell us what type of television you have.
Mar 29, 2010 | Dell Inspiron 600M Notebook
Dell inspiron 600m is allways very hot. can't work on battery for more than 1 min. replaced battery - same problem. looks like the internal charger is shortening the circuts?? thanks, itai
I remember a recall on certain Dell laptop batteries due to their hot running.
Please confirm with your nearest laptop dealer ASAP as they have been known to catch fire!!!
Dec 22, 2009 | Dell Inspiron™ 600M PC Notebook
The Dell Inspiron 600m will not power up when you press the start button. Battery is fully charged. BLY
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
If there is still no display, tell me if there is also any lights that flashes on the (numlock, scrolllock, capslock). Hope this helps
Dec 15, 2009 | Dell InspironTM 600m Notebook
CAN NOT CHARGE BATTERY AND AC POWER NOT WORKING ON MY DELL 600M INSPIRON
the battery could be a bad one or it my be a bad dc jack and would need to be replaced
Apr 28, 2009 | Dell Inspiron™ 600M PC Notebook
Not charging off the power jack
One wrong spark and you'll need a new laptop. Take it to a reputable repair person. A jack is an repair.
Mar 29, 2009 | Dell Inspiron 600M Notebook
Dell inspiron 600m is extraordinarily slow
it may be due to viruses So please try to Run a good rating antivirus and Antispyware I hope this could help you out. Cheers
Jan 22, 2009 | Dell Inspiron 600M Notebook
Laptop won't dock
The inspiron 600M will not function in a D-Dock, but will work in a D-Series port Replicator. (Although the D600 and 600M share the same motherboard, the bottom plastics are different)
After trying the 600M in the D-Dock, it is possible the dock is damaged. I would undock the D630, then delete the docked profile. power off, dock, and reboot and see if it detects and works.
Jan 16, 2009 | Dell Latitude ATG D630 Laptop
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
Dell inspiron 600m sound drivers
Hi the easyest place to find all your drivers for your Laptop is to go to the Dell website.
here is a link to your model of Laptop Dell 600m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_600M&os=WW1&osl=en&catid=&impid=
Nov 08, 2008 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
