Question about Toshiba MK8025GAS 80 GB Hard Drive
No hardrive detected - Toshiba MK8025GAS 80 GB Hard Drive
  • 358 Answers
If your system is showing 'No Hard Drive Detected Problem', a lot of things might be wrong, but I will give you a few steps you can try out to troubleshoot it.
First, try to make sure the drive is firmly connected to the interface where it is meant to be seated,
Then in the BIOS, make sure that it is detected and is selected as one of the drives in the boot sequence, preferrably as the first boot device.
If this does not work, select it as a second drive and get a software called NTFS DOS Professional.
It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If it is not even detected in the BIOS at all, then I'm afraid, you might need to change your hard drive completely.
Hope this helps you out.
Good luck
Posted on Sep 08, 2010
When i try to formate the toshiba satellite L500-226 there hard disk cannot be found
Please check the hardrive under BIOS setup if it is detected. But if not, you have a defective hardrive and you need to replace it before installing the operating system.
Jun 30, 2011 | Computers & Internet
My LG hardrive-2.5" HXD2 250GB-
Oh man, i hate to be the bearer of bad news but...
If you drop a hard drive, especially if it's out of the case, it will jar the sensitive disk inside and ruin it... I don't believe there is anything you can do for it. I'm sorry!
Jan 08, 2011 | Computers & Internet
My computer says: DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. How do I fix this problem. There is a screen before this, but then it turns straight to that screen and will not allow me to do...
1. Check the hardrive cable connection (data and DC supply).
2. Under the BIOS setting, make sure that the hardrive is detected (set to enhance mode), this will detects either SATA or PATA., Exit and Save new setting
3. If still no detect, your hardrive might defect n need new one
Apr 26, 2010 | HP Pavilion MX70 17" CRT Monitor
Can't load xp on hp xw4300. Has sata hdd & ide dvd drive. Xp can't detect hard drive and if press f6 it says there is no floppy drive
replace your cables and try again. if unsuccessful locate your hardrives manufacturer ie: maxtor software MAXBLAST , download the hardrive software utility and ``0 fill`` your hardrive to factory default.
Nov 05, 2009 | Cars & Trucks
I would like diagram on hooking hard drive to hard drive.
If you are trying to put another hardrive into your existing pc I could explain but you if would like something more visual then there is a tutorial here
its simple really since the computer auto detects the new hardrive. the hardest part are the jumpers on the back of the hardrive. You see one hardrive has to be set to Master and the other has to be set to slave. the hardrives can connect to the IDE cable (the big flat cable inside your pc) in any order but they cannot be both set to master. The jumpers are easy to switch and the hardrive itself will have a diagram right next to the jumpers to show you how to move the jumpers to make the selection.
its a great idea to have two drives in your pc in case something happens to the first, but i always recommend a hard backup (cd/dvd).
Nov 13, 2008 | Computers & Internet
My hardrive is not picked up in the BIOS
check whether the hard disk is detecting on BIOS or not
Oct 29, 2008 | Lenovo ThinkPad T61 Notebook
Hardrive not recognised my computer yet the power light is on
go to control panel.. go to Administrative tools.. then .. go to computer management.. on the left pane.. click disk management.. u can detect all ur drives in here including those who are not seen by your MY COMPUTER..
Apr 13, 2008 | Computers & Internet
Lost hard drive
Hi , try restart the computer , if still does not have detection hardrive ,
restart again and it will open starting window setup click del to view setup, set the hardrive to enable.save setting
Feb 06, 2008 | Computers & Internet
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
Toshiba MK8025GAS 80 GB Hard Drive Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
