Question about Dell OptiPlex GX150 SF PC Desktop
Replaced hard drive and now it won't boot up, says hard disk not found
    President:
  • 2,571 Answers
Make sure that it is set as a bootable drive in the bios,
Also, is it being picked up in the bios?
Is it an EIDE PATA drive, are the jumpers set correctly as master, if it is a SATA drive, has it been connected to the main SATA port, it is usually a different colour
Posted on Sep 08, 2010
    Scholar:
  • 95 Answers
Did you set the jumper(s) on the new drive to match the settings on the old drive (usually CS or Cable Select)?
Did you double check the power connector was snug on the new drive? You may also want to double check the connector on the motherboard, SF systems are cranky about moving around, and mave have unseated the motherboard end of the cable.
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
No diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
Aug 31, 2012 | Dell Latitude C640 Intel Pentium 4-M...
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
Gateway mp8708 s/n t23691006485 showing disk error won't boot just shows disk error help me
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 20, 2012 | Gateway Computers & Internet
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 25, 2012 | Computers & Internet
I tried turning my GX60 into a dual-boot and didn't do the partitions right. Sort of put 2 OS in one partition. Now it won't boot and it gives me readings of Drive C: can't be accessed or...
I think that the operating has gone corrupt and needs to be reinstalled. First, make sure that your PC can read the hard disk in BIOS (at boot up, press F2 to enter BIOS and check "Drive Configuration). You should be able to find the hard drive (as well as CD/DVD ROM) here. If not check the hard disk cables etc. At boot up, you may also press F12 for Boot Menu and select the primary hard disk for booting up the PC.
Secondly, boot the PC from CD ROM, Delete the partitions and make fresh partitions for installation of the operating system. You may also add the hard disk of your PC to another PC (as slave) and delete all the partitions from the operating system and make fresh partitions. Place the hard back into your PC and proceed with installation.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 22, 2011 | Dell OPTIPLEX GX60 Motherboard
My HP 4710s had a weird message that pops up after the logo screen. Then it says non disk or disk error strike any key to continue...I do that and the same message pops up...plz help.
the HP cannot boot up because it cannot find the hard disk to boot up from.
You could have a faulty hard drive or the hard drive needs re-seating.
If the HP still does not boot up after re-seating the hard drive go into the BIOS setting and see if the hard disk is detected. If not the most likely the hard disk is faulty.
To get the laptop working again. replace the hard disk, install Windows on the new hard disk plus the HP Laptop's device drivers and your programs.
Mar 20, 2011 | HP Computers & Internet
Won't boot from hard drive
Check the boot settings. The bios may be trying to boot the old hard drive and doesn't even see the new one. If the old hard drive was removed, the BIOS will go to the next boot device. Also, is there something on the hard drive to boot to? If it is a blank hard drive you will need to install an operating system, otherwise it will not boot.
Feb 25, 2010 | Toshiba Computers & Internet
Computers & Internet Logo
Alun Cox
