Question about Linksys Cable Modem
Occassionally, our cable internet dips or stops working and we have been told to unplug and replug the linksys modem, which fixes the problem. Should we change the modem or it is a general problem?
    Sergeant:
  • 486 Answers
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Best of luck :)
Posted on Nov 06, 2013
E900 no internet access
You can try turning off the router for 2 mins and try to access the user interface again . If turning off the device will not work then what you can do is connect the modem to the PC , download Firmware for your router , connect the router back to the computer ,access the user interface again and perform the upgrade .
Dec 07, 2017 | Linksys Computers & Internet
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
b>
Dec 28, 2012 | Computers & Internet
I just updated my internet speeds and was told to reset my Motorola SB5100 modem, but i cant find a reset button on the back panel. How do I reset the modem?
Log in to your modem using 192.168.100.1
You will see a configuration button on the left, click that.
Click the factory reset / restore default settings button.
To simply turn i toff and on click reset cable modem below or simply unplug and replug the power cord.
Dec 11, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
Loss of internet connection to desktop with WRT 160 N
If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
1. connect to modem with an ethernet cable, without the router
2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
Jan 20, 2009 | Linksys WRT160N Wireless Router
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot connect to internet Model WRT54GS
Hi
I would like to know who is your internet service provider and would like to check if the router is configured with your ISP modem.
To configure for different ISPs here is the link
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US/Layout&cid=1166859761879&pagename=Linksys/Common/VisitorWrapper&lid=6187977881B11
The links are there for setting up with DSL as well as cable modem. Do let me know if its working or not.
Thank you
Rakesh
Jan 06, 2009 | Linksys Wireless-G Broadband Router
Emachines t5060
Reboot your computer,
Check your cables in machine especially the one that looks like an oversized phone cord. (cat5). Unplug replug.
If you have cable modem power down along with any wireless router power cable modem up first wait 30 seconds to 1 minutes. Then power router on
If it is dsl just unplug and replug the dsl modem and any attached routers plug in dsl modem first then plug in router if applicable.
If your at work try
Dec 26, 2008 | E-Machines eMachines Desktop PC
Need tech advice
No and why doesn't your internet provider... provide a cable modem?? Did you just ask them to enable broadband internet service? So now you'll have to provide your own cable modem.
If what you say is correct you need a cable modem like a motorola surfboard from BestBuy.... then the cable modem plugs into your Linksys router and your PC's plug into the linksys router also.
http://www.bestbuy.com/site/olspage.jsp?skuId=8229044&st=motorola+surfboard&lp=1&type=product&cp=1&id=1168043113583
May 05, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys  Cable Modem Logo
43 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
