Question about Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens
My lense has problems locking focus especialy when i zoom.It was not like this before.
  • 169 Answers
What kind of lens is it? 18-55mm ?
Posted on Sep 29, 2010
My HVR-V1U has a focus problem. In manual focus mode, when I zoomed in and focus and then zoom out, it is not in focus anymore. But if I leave the camera in auto-focus it is fine. I don't see a way...
That's the backfocus problem. Take your camera to a Sony service.
If the lenses are ok, they will do an adjustment. If the lenses are defective, they will
replace the lenses, but that costs much.
Sep 22, 2011 | Sony HVR-V1U Mini DV Digital Camcorder
Why are my pictures blurry when focus is all the way out, and focused when all the way zoomed in? this is also visually obvious on the lCD screen. zoomed out( out of focus)..zoomed in( in focus).
your camera's lense is clear? try clean it with suitable cleaner for lense. If still not working, check your user manual for setting
May 09, 2011 | Cameras
I have a Tamron 28-200 lens for my Canon EOS 20D. My brother took it to Africa, and since it's return, the lens will no longer zoom out by turning the zooming ring. I spoke to another photographer who...
Some of the long tele's like that have some sort of locking mechanism on the side to prevent lens creep. Look for switches other than your aperature lock and auto focus/manual switch.
Mar 15, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Apr 09, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
Canon AF Issues
Change from auto focus to manual focus or focus using only one focal square and change the setting to One Shot. You may need to shoot in Manual (M) mode though. Any of the "auto" modes will not let you.
Sep 14, 2008 | Canon EOS 30D Body Only Digital Camera
Lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Dec 30, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Zoom Problem
There are two components to a camera lense. One adjusts the final lense distance from the CCD imaging chip the other adjusts the distance between the lenses in the assembly (which zooms the image in and out). It sounds like something inside the lense came loose and when you zoom the lense the focal lense is moving with the rest. The lense will probably have to be replaced if it cannot be taken apart. Odds are something is broken inside anyway. This could be something you might be capable of, I have no way of knowing. If you do not think you are up to the task, have a reputable repair shop do it. Cost should not be excessive. I would think less than $100 US plus the cost of the part. Good luck.
Jun 16, 2006 | Samsung VP-D103i Mini DV Digital Camcorder
Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens Logo
63 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
