Question about Jet 3 Ultra Power Chair
WHEN I TURN THE POWER ON FOR MY JT3 ULTRA POWER CHAIR, THE LIGHTS THAT INDICATE THE STATUS OF BATTERY BLINK ON AND OFF (REGARDLESS OF BEING FULLY CHARGED OR NOT) AND THE CHAIR WILL NOT MOVE. SOMETIMES, IF I SMACK THE ARM OF THE CHAIR AND TURN IT OFF AND THEN RIGHT BACK ON, THE INDICATOR LIGHT WILL STOP BLINKING AND WORK AS ADVERTISED. OTHER TIMES I SIMPLY TURN IT OFF AND ON SEVERAL TIMES AND SAME THING, IT STOPS BLINKING AND WORKS GREAT! IS IT A SHORT IN THE WIRING OR DO I NEED A NEW BATTERY. MY SISTER GAVE ME THIS CHAIR AND SHE TOLD ME IT HAS SIT THROUGH LONG PERIODS OF NONUSE WITHOUT CHARGING. WHERE SHOULD I BEGIN TROUBLESHOOTING???
  • 692 Answers
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Posted on Sep 08, 2010
When i turn chair on lights on controller blink and also beeps loud constantly, what do i do, it wont move either
The pattern of lights and beeps should tell you what the problem is. The chart is in the manual. You can download one if needed.
Mar 16, 2014 | Jet 3 Ultra Power Chair
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
Mar 24, 2011 | Jet 3 Ultra Power Chair
Yellow lights blink and chair does not move on Jet 3 power chair
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jun 15, 2010 | Jet 3 Ultra Power Chair
The chair was outside and got a small amount of rain on it. Now when we turn it on, the lights (that show battery charge) blink fast and it will not move. My dad is grounded until we can figure this out....
Hi. Count how many lights are flashing, it is showing a fault code. Let us know, or contact your local dealer. Check that the free-wheel levers are in the correct place. Good luck. Neil.
May 19, 2010 | Pride Jazzy 1103 Ultra Standard Power...
The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
May 12, 2010 | Jet 3 Ultra Power Chair
Chair no longer charges, no flashing or blinking, lights,
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I can fully charge the Chair and my battery lights will flash Red after about a mile.. I have fully drained the batteries and when I plug the Chair in, the Meter goes to #4. the Meter has 1-6..
It sound like your batteries need to be replaced. how old are they? The battery life eventually dwindles down to almost nothing it says its full because it is full to its capacity however it's capacity has depleted.
Jun 23, 2009 | Jet 3 Ultra Power Chair
All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
Jun 06, 2009 | Jet 3 Ultra Power Chair
All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Apr 28, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
392 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
