Question about Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill
I used my 1199VSR without the right size extension cord (too small of a A.W.G. size) but dont recall a burn smell. When using the extension cord it was working fine then started going slow and then it stopped working all together. I'm thinking it's the armature.
  • 490 Answers
Howdy, I am willing to confirm what I believe you already know; it's cooked. Now about fixing it You can do it yourself with bosch parts for almost the cost of the drill, or have it done for somewhere between free and ? by Bosch depending on how long you have had it. Bosch has a prorate form of warranty repair that sometimes works out really well.
Whichever way you choose to go, this link will help you it get dealt with pretty darn quickly:
http://boschtools.com/Service/ProductServices/Pages/ezship.aspx
Hope this helps some:)
Regards, Farmerbear at FixYa.com
Posted on Sep 09, 2010
AIR COMPRESSOR smells like it is burning
is it straining to run?is the compressor running on a extension cord that will cause more of a draw exp if the cord is to small
Apr 17, 2012 | Coleman Powermate 11 Gallon Air Compressor
I've recently bought a pair of WESC conga headphones which comes with 2 extension cables. The first is long and the second is really short and when i use it while listening to my music it makes the...
i had the exact same problem but i just removed the smallest extension cord its like only a few centimeters :P after that the sound got clear without having 2 use the button
Aug 21, 2011 | Wesc Conga Headphones
Smell of rubber or plastic burning when in use.
Does your unit have a power nozzle?-- could a belt be slipping at the floor nozzle?
When does the smell begin-- Immediately-- or after running awhile?
Do you feel anything in the power cord that is HOT?-- or the wall plug?
(You are not using an extension cord, right?)
Tell us more about the machine, and when and where you notice the smell the most--
Mack B
Dec 28, 2010 | Vacuums
Used extension cord on freezer then it stopped getting cold.
never use a extension cord unless it is of a larger gauge wire size eg: #12. as opposed to standard #16 or #14. the compressor/motor will not get needed power and burns out.
Jul 12, 2010 | Frigidaire Freezers
WHAT SIZE EXTENSION CORD FOR GA7021 SHOULD I USE AND MAX LENGHT? BURNING UP GRINDERS
Well for 15A the minimum wire size in your cord should 14 gauge, Length can't really be specified but you want to go for less resistance in the cord, thicker wire and less length will give you less resistance (more so thickness). If your grinder works fine without the extension cord, I would recommend getting a heavy duty extension cord with 12 gauge wire and trying that.
May 25, 2010 | Makita Angle Grinder 7" 6600 Rpm, 15 Amp
Does not run any longer....smells like it is burning...
probable not worth repairing, if it smells then it got hot and might have melted the windings on the armature or field,, but take a look inside the handle area for any signs of burning and check the condition of the brushes before buying new one.
May 07, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Air cond & electrical outlet in 1999 sprinter by keystone 33 ft
One of your breakers in your main panel should be for either one of those. Simply test receptacle for power as you try flipping each breaker off and on, until you find the right one. Quite often a high amperage draw item like electric frying pan, or hotplate plugged into the one by the kitchen area is the culprit. If they smell, or appear burnt or scorched, they should be changed, as well as the entire circuit tested for proper size wiring, as well as rated receptacle to handle big power( amperage draw). Extension cords will also cause same problem. Make sure if you have to use an extension cord, that is a heavier gauge wire, approved for that use, and is as short as possible. I'm assuming your AC is plugged in to a receptacle, and not on roof?
Apr 23, 2010 | Heating & Cooling
I have a CH WL611701AJ compressor. The motor starts and runs for approx 15-20 seconds before blowing breaker. I have replaced both capacitors, still blows breaker. Removed piston to allow motor to...
This may seem a bit simplistic but how are you hooked up to the outlet? Are you using an extension cord or is the compressor plugged in only using the supplied power cord?
If you are using an extension cord then you are going to pop the breaker every time you use it. Infact the manual states
"Never use an extension cord with this product. Use additional air hose instead of an extension cord to avoid power loss and
permanent motor damage. Use of an extension cord voids the warranty."
Air compressors don't like extension cords.
It simply draws to much for an extension cord to handle.
Depending on whether or not your warranty is out there is a simple solution. Find the biggest gauge extension cord you can
If your not using an extension cord and it's ran in the past where it's plugged in now then check the circuit because there must be new draw on the breaker
You said the breaker is 20amp. correct? The compressor should be run on a breaker dedicated to the compressor only.
Even though you should use a longer hose instead of a longer power cord you can get away with it. But forget about wire gauge size you need to think wire diameter. The extension cord I made for my compressor is approximately 3/4" thick. That is the only way I was able to use an extension cord on mine. A good place to get that size cable is a boat supply store. The cable used for shore power on boats works.
Hope this helps but if not please let me know and I'll try and help anyway I can to solve your problem.
Nov 15, 2009 | Campbell Hausfeld 28 - Gallon Air...
My black and decker leafhog blower/vac smells like something is burning
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
Nov 08, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Defective plug Honeywell HZ 680C
Question:
*All Heaters*-Where can I get parts for my heater? Answer: Unfortunately, we do not have any replacement parts available online for heaters. You can obtain parts by calling consumer relations at 800-332-1110. The only parts currently available are replacement wheels for oil filled heaters. If you are looking for any other parts, please call us or send an email to ConsumerRelations@kaz.com and let us know the model number of the heater, the length of time you have owned it for, and a detailed description of what is wrong with it.   Question: All Heaters-Can I use an extension cord with my heater? Answer: You should avoid the use of an extension cord as it may overheat. However, if you have to use an extension cord , be sure it is a polarized cord of 14 AWG minimum and rated no less than 1875 watts.
http://www.kaz.com/kaz/support/FAQ/?ProductCategoryFAQAction=renderProductCategoryFAQList&ProductCategoryId=1bc8ee52577f77289f9a193ce1ba3ee3
 I could find no recall on you product. They do not supply parts. I am sure you can match up the plug and cord at any good hardware or appliance parts store. Are you sure it is the cord?  The element could be shorted out.
DO you have an ohm, meter or small batter light tester to tes t the cord and eliments with?
Dec 06, 2007 | Honeywell HZ780 Oil Filled Radiator Heater
Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill Logo
234 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
