Question about Metabo WE14-150 Quick Angle Grinder
METABO POWER GRIP WITH FLASHLIGHT when charging the battery does the charger indicate when charging complete
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: Metabo 18V cordless drill lithiom ion batteries not taking charge
Some batteries develop 'memory'. Run the batteries down until they are completely dead, then recharge them fully. Do this a couple times to get them back to normal.
Posted on Jul 02, 2009
  • 10 Answers
SOURCE: I have a metabo battery charger c45 & it
If it is flashing red without a battery installed, there is problem on the circuit board. It will best to replace the charger as repair componants are not available.
If it is only flashing when a battery is installed, it may be a bad battery.
Posted on Dec 11, 2009
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Worx charger
Usually the indicator lights while charging is underway but sometimes the indicator is on whenever the charger is connected regardless of what's happening or supposed to happen. Try charging the battery, ignoring the indicator. Obviously if the battery does not charge, the fault is with the charger
May 11, 2013 | Worx 18V Cordless Hammer Drill Driver with...
Batterys dont charge
Very rarely will you come across 2 bad batteries in a kit. If you have 2 batteries that will not take a charge and they are from the same kit. The common denomiater would be the charger. I would look into that. when some chargers fail the lights still work but the charger does not actually charge. If posible double check the same batteries with a different charger.
Aug 29, 2012 | Metabo BSP15.6PLUS 15.6 Volt Cordless...
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Charger light does not come on
The red light indicates the batteries are charging and green indicates the charging is complete.
Jun 12, 2010 | Stinger Streamlight 75000
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Jun 03, 2010 | Metabo Drills
Charger lite will not come on! there is power to charger and if you wiggle lite the charge lite will blink but not stay on
It sounds like the battery is completely dead. Try placing it in the freezer for a couple of hours and attempt to charge it. If that doesn't work, you will need to know the make a model of the flashlight it goes in as well as the voltage. If you have to purchase a new battery I would suggest you purchase a Nickel-Metal Hydride (NiMH). NiMH's have much higher capacity than NiCd's and don't suffer from memory effect.
May 20, 2010 | Streamlight Ultrastinger Rechargeable...
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Jul 02, 2009 | Metabo 685009520 COMBO 4.1 18V Cordless...
Metabo WE14-150 Quick Angle Grinder Logo
114 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
