Question about Dell E173FP 17" LCD Flat Panel Monitor
Hi the sceen goes black when it is switched on for ten minutes if I switch it off for a few minutes the sceen comes back on. It will then shut off again after a few minutes. Thanks Alan
  • 439 Answers
This is due to the inverter for the backlight, or the backlight itself going bad. You are going to be better off replacing the screen unless you are handy with electronics.
Posted on Sep 08, 2010
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Our furnace went into lock out and so I cycled powere and it reset it started working again but not correctly. The inducer motor wis coming on for a few minutes then the hot ignition comes on and the gas...
Boy it sounds like a high limit opening up and shutting off the gas valve. It won't shut off the blower because it wants to cool off thge furnace. Check for any restriction in the air delivery system, filter, registers. Check for blockage of the exhaust vent.
Jan 08, 2011 | Heating & Cooling
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
Dryer runs for ten minutes then stops
there is not a whole lot of info here......but it could be that your timer dial is worn out! on the other hand dryers have thermal protection switches to keep them from over heating! (FIRE!) you could have a few different problems if this is happening.
May 24, 2009 | Dryers
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
