Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Sir, I have Sony Trinitron 21' KV2197 model TV which has twice been repaired ocally. The problem were of SMPS. But this time, again the set blown off expecting SMPS circuit problem vis-a-vis EHT problem as cut photos is seeing from botom side of the screen. I think to get the kit(board) replaced. Let me know: From where I can get 21' original sony kit. How much it costs. Can this be replced with some other equivelant/digital spare kit of other model. Can I replace the same as being TV Mechanic having experience more than 15 years. Regard, Harjinder Kumar.
welcomejee
  • 10594 Answers
SOURCE: sony tv model kv-sz29n50 trinitron
Please confirm do you see this kind of picture in TV?
Mention exact model number to help you.
Posted on Oct 22, 2008
techman
  • 3130 Answers
SOURCE: sony trinitron KV G21S2(i think)
Id you have no TV repair experience, play it safe and take the set into an authorized Sony repair place to estimate the cost to repair. Yes I know it would be nice to repair, but how much do you know about component level printed circuit board repair? You will need to first get a service manual, know how to read a circuit diagram, thats a schematic, and know how every circuit works with each other to make the TV set operate. I do appriciate the fact you would like to repair this yourself, but there is no magic fix in most cases when it comes to electronics. There is circuit diagnosise involved. Best advice would be to call in a pro to assist you in these types of repairs. Good Luck
Posted on Jun 23, 2007
SOURCE: Sony Trinitron Vega KV-34HS420
MUZ,
Any luck with your TV yet?
Posted on May 21, 2008
  • 4234 Answers
SOURCE: Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Posted on Jul 14, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
Posted on May 19, 2009
What to do no power on 21" sony Trinitron 1997 ?
first check main card and then check fuse .if fuse is blown put new one amp fuse.af set is ok leave it .if not work then chcck seitching transister and S.T.R 6007and oo120volt zenner diode.
Sep 19, 2014 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony trinitron 21 standby twice blinking
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition
Aug 20, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a SONY TRINITRON TV Model no. KV-XR29M80. Unfortunately, the Remote Control supplied with the original TV set is not working. How can I obtain a replacement Remote Control for the set ? I live in...
Hello
The original remote control of your TV is available at Ebay. It is priced $8.99. Just order them with the exact model number of your TV and order for a remote control of the set. They will get it at your doorstep. OK.
May 29, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Picture was great day before, next day picture would not come on.
I had the exact problem. Turned it off at night, next day nothing. Set is KV32FV16, manuf. in 2000. Repair tech. found bad fuse that was all, set now working. Fuse located in lower right hand side of chassis. Fuse appeared to have deteriorated rather than blown. Good luck.
Mar 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV28WS2V blinks twice constantly
Good day sir. it depends really on the availability of parts, get first estimate for the repair. its a major one but not that expensive.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No sound (sony trinitron kv-2197pf 21" tv)
try to short the spider transistor along ic amplifier. it is in a mute
Oct 05, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
206 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
