Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
I don't know how to open the lid at the back. When I pressed the button at the front, only the lid at the front opened.
    Problem Solver:
  • 7 Answers
That means find the other button k
Posted on Sep 09, 2010
Buttons work, but the safety feature wont let it run unless I lean on the lid
Don't know if it's a front loader or a top loader. Either way, there is a safety switch in the lid. On a top loader, there is a little button at the back of the lid opening, which the lid pushes as it closes. the lid may be out of line, or warped. Did anybody stand on the lid ? If bent, try to twist the lid straight. You may also try temporarily wedging a folded matchbook cover between the lid and button until you can fix it correctly.
Mar 07, 2015 | Washing Machines
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
Everytime I lock my computer,shut the lid or leave it untill it goes black, it will not come back on when I touch the mouse pad. However when I got this laptop it worked and when I opened the lid and...
Well by default Closing the Lid will cause computer to go to Sleep mode and you can't wake it up using mouse. However you need to press power button to wake it up.
But as you said it was working the way you explained then seems like Power settings on your computer are changed
To check the settings Got0 -Control panel and click on power Options Goto - Advanced and find the Lid open/close actions You can change it there If you don't want your computer to goto sleep mode with the lid close, you can simply disable it.
Hope this worrks
Jul 14, 2011 | Computers & Internet
When I push the start button I get a beep and the message is: "od" and the washing machine doesn't start
The FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The OD alarm means the FAV6800A/FAV9800A Control Board has not sensed a lid open condition for three completed wash cycles even though you opened the lid.
You have lost signaling from the Left Lid Lock back to the Control Board.
What I would do next is remove the Left Lid Lock and very carefully open it up. See page 34 for removal steps. Just remove the left lid lock don’t worry about the right. Once you have the Left Lid Lock in your hand you need to open up the case halves.
I found it is very easy to break off the enclosure locking tabs. I use a fine flat jewelers screw driver and X-acto blade and work around the locking tabs to open the case halves. I wedge small paper clip ends or tooth picks in the case halves as I work around the tabs. Once the case halves are open I believe you will find corrosion issues such as seen in my pic’s.
You can clean up the corrosion with WD-40 and finger nail
emery boards.
Hit the plug end with a couple of squrits if WD-40.
I believe you will find the black lead has broken loose from one end of the magnetic reed relay. It can be soldered back on. If you don’t want to deal with that you can order a replacement. Left Hand Lid Lock.
Let me know if you have questions…. Rich
Nov 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The drum will not turn when you start the dryer. The belt will need to be exchanged but how can I access the belt?
You have to open the cabinet and remove the front. Some have screws through the front, others have the screws on the inside that are accessed after raising the lid. To open the top slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. If you don’t see the screws on the outside, they on each side on the inside holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on. If there isn’t an opening on the back to access the motor pulley, you have to reach under the drum from the front to thread the belt onto the motor pulley. When putting the front panel back on you need to guide the drum and the front panel together at the felt seal around the door opening. Vacuum the cabinet well while it is open and make certain to unplug the power cord and turn the gas off if applicable.
Jun 07, 2009 | LG DLG3788W Gas Dryer
When I try to change my ink cartriges the carriage will not move
With the lid open, you will see the two arms that stick out of the lid, and go into the body of the printer, they are black. and on the far left and right of each side of the lid. They have Teeth on them like a saw. When the lid is closed, these go down into the printer, and hit a little micro button on the back of the printer. When this button is pressed, the printer knows that the lid is closed. I am guessing that this button has gone bad, so the printer does not know you have opened the lid, and therefore it does not move the print cartridges into the parked posistion.
Jan 18, 2009 | HP Photosmart 2575 All-In-One InkJet...
Hotpoint WMA34 washing machine
Remove top cover, 2 screws are hidden behind 2 plastic covers at front of lid, push the lid back to remove , undo the screws that hold the dispenser, and slide the console panel to the right, then you can access the control board and reset the button,
Sep 22, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Open a laptop
u dont have any button to open the lid it is lil tight app lil force not too ...
May 20, 2008 | Computers & Internet
Refill colored ink, what holes, lexmark x5470
To open the printer, just above the front control panel you use both hands & pull upwards. The whole top of the printer will open up. The ink cartrifges will be close to the center of the opening. The printer should be on for this. There are two ink cartrages. The one with the black lid is for your black ink. There is a small tab in front of the cartridge lid. Push down on the tab & the lid will open. Remove the old ink. Remove the tape that is protecting the the bottom & copper back side of the new ink. Place the ink into the printer. The copper back that runs from the bottom & up the back side about 3/4" goes into the printer cartridge. The colored ink goes into the other cartridge holder, it's lid is blue. Again press the tab just in front of the lid & it will pop open. Repeat the above removing the protective tape & install the ink.
The ptinter will want to run either a test page or allignment page or both. You will need your manual. If you do not have your manual you can download it from this site. Click the link below.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=f7f0a21c03aee016b79da0cdbb74cf9f&q=Lexmark+X5470
Click "Start download" & save it to your Pc.
Have fun!
please vote...
Jan 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
79 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
