Question about Sport & Outdoor - Others
Treadmill not running at all use to run for while then just stops . E1 displayed also comes up error no speed signal feedback please check signal wire or speed set Have checked wires all seems to be good
  • 33 Answers
Your problem might be that a magnet has fallen off. Here's guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
I have recently installed treadmill motor brushes but now treadmill is not calibrating,calibration takes start and when calibration comes to check the slow speed it stuck there and keep calibrating it
Hi There, Please check that you have the small feedback connectors snug and proper. Some treads have them on a front or rear roller and some also have a motor feedback. Or - Try to power down and back up and try to run treadmill normally, not in cal mode, and see if the unit responds to your speed selections correctly. During "calibrations" the upper board (usually) is looking for a specific feedback signal, if it cannot be found it usually stops the tread, but in cal mode it may sit there waiting for it's feedback sweet-spot before continuing. What make, year and model of tread?
Jun 02, 2016 | Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
How long does it take for someone to help me, on this site.
How fast you get answers depends on many factors. I just picked up your question but have spent time finding and reading the manual. I am by no means a treadmill expert, but my first thought was treadmill belt tension was too loose to keep the movement sensor happy.
Moving the belt manually would be irrelevant as the electronics would not be monitoring to throw up the E1 Error..
The manual tells you to check all these things.
E1
Loss of Feedback Speed Sensor disconnected Check Speed Sensor
Connection
Speed Sensor Misaligned Check Sensor position
Faulty Speed Sensor Replace Speed Sensor
Loose Display Connection Check Display Cable
Connection
Faulty MCB (D2 LED on) Replace MCB
Faulty Drive Motor Replace Drive Motor
If BH Fitness are being no help, I would be asking them to take the machine away or get it fixed on-site.
So does the belt turn when you switch it on? Is the belt centrally aligned when it spins?
Page 35 shows belt adjustment and I would guess tension although not specifically mentioned.
http://www.bhfitnessusa.com/manuals/final/ts2.pdf
Jan 05, 2016 | Bh Fitness TS2 Folding Treadmill
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
E1 error after start
this ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display. see the diagram attached.
God bless you
Nov 27, 2013 | Kettler treadmill Pacer
Treadmill E1 Error
Version:1.0 StartHTML:0000000168 EndHTML:0000001348 StartFragment:0000000468 EndFragment:0000001331
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 29, 2013 | Exercise & Fitness
I get an error message E1 on my Athlon model Simplicity treadmill. Belt stops. Any ideas on what this means?
Step 1:
ERR 1 - Motor Movement
Clean the s.speed , test for open or faulty-see the diagram for adjust. tight the connector very well.
God bless you
Step 2:
Feb 08, 2013 | Exercise & Fitness
Code e1 on my treadmill
please see the indication for error 1. and fix it. see the block diagram
Lube the Deck belt and rollers bearing too.
Jan 01, 2013 | Fitness Equipment Estore Bremshey Scout...
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
Sport & Outdoor - Others Logo
354 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
