No audio is heard - Computers & Internet
  • 57 Answers
Check sound properties or deveice mananger.. or try re-installing sound driver as well
Posted on Sep 08, 2010
The audio is not heard in my TV, but this looks perfectly, neither is heard through the headphones
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 07, 2015 | Televison & Video
I have a panasonic spatializer 3-d stereo tv, great picture but no sound??
Check whether the mute button is activated or jammed. Try using a headphone and check whether audio is heard. If not, connect the same input to a different TV and check whether the audio is heard. If yes, this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
My self diagnosis problem. (standby)imdicator is flashing in red,six times between two second break ??????
Information from Sony:
Audio Output Error (6X)
There are three possible failures that can cause a 6X protection mode, and they are as follows.
Short Audio Amplifier Outputs
Lose of 15V Supply
Lose of 9V Supply
The key to determining what to check first is if audio is heard before the TV shuts OFF.
If audio is heard before the TV shuts OFF, then the next step is to check the 15V supply at CN7503/pin 1. If the voltage is missing replace the G1/G2-Board. If the voltage is present, first check the fuse PS7001 for a possible easy fix. If the fuse is OK replace the AU-Board.
If no audio is heard before the TV shuts OFF check for 9V at CN9502/pin 1.
If the 9V is missing replace the BU-Board. However, if the 9V is present check and confirm that the protection circuit output voltage is making it to the Main Microprocessor IC1001/pin 26. If 2.8V is present at IC1001/pin 26 then the Main Microprocessor is defective. Replace the BU-Board. If the voltage at IC1001/pin 26 is 0V then the audio output circuit has actually failed. In this case, replace the AU-Board. A shorted audio output or a DC voltage level measure across the audio output will cause a 6X protection mode indication. In either case the problem will exist in the audio circuitry on the AU-Board.
May 24, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No audio when scanning, however, audio is heard wh...
Check to see if there are some channels locked out ....L/O....hope this helps...
May 14, 2010 | Radio Communications
N82 - No Audio in Radio; Bluetooth not working
What is your N82 version ? .... is it v35
Aug 12, 2009 | Nokia N82 Handheld
NO SOUND HEARD
In the Device Manager, which I assume you are familiar with, right click on the disabled sound card and choose Enable.
good luck
tony
May 15, 2009 | Computers & Internet
Sound is heard only sometimes when comp turned on.
You have to download audio codecs for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Jan 03, 2009 | Edirol UA-4FX External Sound System
I can hear audio on all stations except one?
Check on your remote for a button labeled MTS/SAP or something similar -- try pressing it (possibly more than once). Sometimes this can cause audio to be heard on some channels but not on others...
Jan 01, 2009 | Polaroid FLM-4201 42 in. LCD Television
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Computers & Internet Logo
David Payne
David Payne
