Question about LG Televison & Video
Hi, I have a LG80fr 32 inch LCD TV, it's 1 year old (out of warranty) I am facing issues with turning on, Once you start it it takes time to start, recently it start on after a very long time, works fine while running.but takes very long time like 2/3 hrs, sometimes it doesn't start also. Is it something to do with the capacitor coz I checked the entire powerboard and found(visually) that none of the capacitor is brusting or swollen ..... please help me fix this .....
  • 579 Answers
SOURCE: ESA 42 Plasma picture problem
The power supply is having difficulty. The typical cause is underated electrolytic capacitors. I would examine all the caps (round cylindrical cans) in the power supply and see if any of them are bulged. Not a bad idea to just replace all of them with better rated parts.
These type of caps have all kinds of specs. Not just voltage and capacity, but also temperature, case size, and obtuse stuff like dissipation factor. Most all power supplies use switching type designs that run at serious frequencies (not the old 60 hz - more like 50khz) that stress out these electrolytic caps and many circuit designers (or their cheap bosses) don't specify the better parts. Replace them with the same capacitance, but higher voltage, and higher temp parts (hopefully they will not be too big physically).
Ya, I know you paid $$$ for this TV and they scrimped on cheap parts. Yup, the more expensive a product is, the more pressure the bean counters put on keeping the price down.
Hope Ya Fix It.
Posted on Feb 12, 2008
SOURCE: Vizio LCD 37 Inch Turns Off Randomly
I had the same problem with MY Vzio L32 randomly powering itself on and off. The problem Is U26 on the main board. Solder a 10K resister to pins 2 and 3.
Posted on Jul 15, 2008
SOURCE: westinghouse 32 inch screen goes blank
I had the exact same problem and I fixed my Westinghouse 32 inch by replacing the power supply. You can purchase it at
http://www.partstore.com/Part/Westinghouse+Digital+Electroni/Westinghouse+Digital/4900211680/New.aspx?ModelMfgName=Westinghouse+Digital+Electroni&ModelBrandName=Westinghouse+Digital&ModelNumber=LTV32W1
I takes about 15 minutest to replace. Just take the back lower panel off and replace the power supply. Mine works like new now.
Posted on Jan 25, 2009
  • 3 Answers
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Posted on Apr 24, 2009
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Posted on Nov 04, 2009
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
32 inch rca lcd when i turn it on the the green light comes on but there is no picture or sound. Unit does not respond to pressing the source button or any other. did this a few times before but i just had...
If it is under a year old, do not attempt to repair it, call the manufacturer it should still be under warranty. Sounds like a mainbord issue but again let the warranty take care of the repairs.
Sep 24, 2011 | RCA L32HD31 32 in. LCD HDTV
My 20" rca 20f424t cuts
That sucks about your tv. Mine just turned 3 years old. Never had a problem with it. But you seriously can't expect wal-mart to take back and exchange a 3 year old tv. Come on. That would be stupid for walmart to do. Even RCA prolly dosent do more than a 1 year warranty. Unless you purchased the warranty from walmart, it will be cheaper to just get a 19 inch lcd tv now. Cheapest I see them on sale for is only $99.99
Aug 02, 2011 | RCA 20F424T 20" TV
I have a black approx 12 inch streak on the left side(facing tv) of my flat screen Bravia Sony TV . It is approximately 3 years old. It started as a brown panel..then became a fine lined multy colored...
sadly you have a bad panel. Sony panels carry a two year warranty.
your best hope is to call Sony and ask for a warranty extension to cover the cost of the part.
Apr 12, 2011 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Olevia 32 inch tv turns itself off after a min everytime i turn it on its 4 years old? what do i do
Aside from trying different power cords, I'm afraid there isn't much you can do with an LCD TV with a power issue. Since it's four years old, I'm assuming it's no long under warranty. Did you purchase it with an extended coverage plan or anything?
Sorry to be the bearer of bad news. Hope it helps, though!
-Kevin
Jan 04, 2011 | Olevia LT32HVE 32 in. LCD Television
Had power surge tv will not work fuse blown or power supply tv is only 3 months old
Hi
This TV should still be under warranty. Most new TV's have electronics warranty of 1 year.
Mar 13, 2010 | Sansui HDLCD3210 32 in. LCD TV
I have an AOC 32" flat screen. the left hand side of the screen displays vertical lines only. The rest of the picture is perfect. The set is only 1 year old.
Hi my name is Roety,
I can help you with your issue ,
Sorry to say , but these LCD TV Screen do go bad.
There is a board thats part of the screen called the Tcon
You can check the ribbon cables to the tcon board or try to get AOC to warranty the TV under the 1 year warranty.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 01, 2009 | AOC Envision L32W461 32 in. LCD HDTV
I have a 46 inch Samsung LCD model number LN-T4665F and I have been having issues w/ the power/ clicking sound! It used to turn on and clicked a few times now just clicks all the time and doesn't turn on...
1. It is not a two years old TV, but a 9 years old one.
2. The common problem of the symptoms is a defective main power supply, you may check to see that are there anny "Pup-Up" electrolytic capacitor on the power supply, if there is any, replace them, you may fix up the TV
Jul 02, 2017 | Samsung LN-S4692D 46 in. LCD HDTV
Insignia lcd 37''powering off and right back on by itself!
Hi Ed,
Since the TV is less then a year old and still under manufacturers warranty, I would suggest to take back to the vendor to get it fix because this LCD behavior is not going to get any better.
The failure on this TV is related to a power supply in most cases if the TV is turning OFF by itself or needs to be unplug to let cooldown and it works afterward.
Feb 28, 2009 | Insignia 37" LCD Flat-Panel HDTV
Dell 32 inch LCD Tv volume and menue problems
We also have a 32" LCD Dell flat screen tv #W3201C that has no sound. It's about 2/12 yrs old. One speaker started having a problem and we disconnected it. That was a couple weeks ago, now there is no sound at all. Dell should not be let off the hook so easily. Obviously there is a problem with the tv and it should be Dell's responsibility to make it right. Does anyone know if a class action suit has been initiated?
Mar 08, 2008 | Dell W3201C 32 in. LCD Television
Televison & Video Logo
