Question about Samsung NC10-14GW Notebook
My samsug notebook when i press the m key changes to 0
  • Tony Montana Aug 19, 2012
    press the key fn and f11 together to turn num lock off .thats the solution
    Problem Solver:
  • 10 Answers
Ur num lock is switched on switch it off by pressing the fn key and num lock key
Posted on Sep 08, 2010
Hey every one, the solution is here, to solve this little issue press f11 and fn key at the same time ,I guarantee you it would help you. And by the way f11 key is num lok in the samsung laptop ,gracias!
Posted on Aug 19, 2012
    hey every one, the solution is here, to solve this little issue press f11 and fn key at the same time ,I guarantee you it would help you. And by the way f11 key is num lok in the samsung laptop ,gracias!
    New Friend:
Exactly press fn and f11 at the same time it works.
Posted on May 27, 2013
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
TRY
Press 0-8 then enter 400 and make it 0 then press print switch, if it doesn't work you have to change the thermostar, then if not working change heater, it not then IH board, and the last solution is to change the system board.
OR TRY
This problem is caused by the thermostar in the fuser section. To reset shut machine off, then turn it on while holding doen the 0 and the 8 key down for more than 10 seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a number in the screen, press 0 then start key this should reset the code if not the themostars need to be replaced.
Nov 19, 2015 | Toshiba Office Equipment & Supplies
How to reset administrator code i have lose
Procedure 1) Press the Utility key 2) Press the following keys in this order. Stop-> 0-> 0-> Stop-> 0-> 1 3) The Service mode screen will appear. 4) Press [ Admin. Registration] 5) Using the 10-Key pad, type the 6-digit administrator number (000000 to 999999) to be register or changed. 6) Press the [Yes] key to register the administrator number.
Oct 04, 2014 | Konica Minolta bizhub Office Equipment &...
Setting new price for plu
Using the 'P' key, 'C' key turn the key to the PROG position, PRESS the 0 (zero) key and then 0 (zero). At this point, press the key of the item that you wish to change or Enter the PLU # and press the PLU Key. If the description of the item is ok then press 'cash/enter' and then press it again. You should be on the PRICE/Halo line, Change the amount to the correct amount and press cash/enter at this point you can then press the clear key and then turn the key to the 'REG' Position. Press the Key of the item you changed and it should display the new price.
Jun 20, 2014 | Samsung SAM4s ER-650 Cash Register
How to reset IR2020I
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
May 09, 2014 | Canon iR 2020i Laser Printer
Blue keys layout
The "Blue" keys you are referring to are the embedded numeric keypad that can be activated by pressing the numlock (NumLk) key once. You will notice that the LED (second from the left with the number "1") will come on.
This changes the following keys:
NumLk On NumLk Off
1 J
2 K
3 L
4 U
5 I
6 O
7 7
8 8
9 9
0 M
Pressing the blue Fn key does not affect these keys
Good Luck and Best Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer sinve 1989.
May 06, 2014 | Panasonic Toughbook W2 Notebook
System error E000 of canon mf4100
I think you need to reset....
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key. Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1). Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 14, 2012 | Canon imageCLASS MF4150 All-In-One Laser...
I own a Asus k501 laptop and every time I turn it on a screen comes up and says, "Check cable connection! PXE-MOF: Exiting Intel PXE ROM." What can I do about this?
You may want to open up the slot that the hard drive resides in and make sure that it is connected into its socket correctly. If you've done this...you should try:
1. Power the notebook on, and immediately begin tapping F2 to get into the notebook BIOS.
2. In the BIOS use the arrow keys to select the Boot Menu.
3. In the Boot Menu will be "Boot Priority Order" and below that will be a list of devices. The first in the list should be "IDE 0".
4. If "IDE 0" is not the first, use the arrow keys to highlight "IDE 0"
5. Use the designated keys to move "IDE 0" to the top.
6. Press the F10 key and press the enter key to save and reboot the computer.
Jul 21, 2011 | ASUS Computers & Internet
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
Media Test Failure, Hardware Problem?
reset your BIOS settings to default, to do this go into BIOS screen and choose return to default settings.
Jun 17, 2009 | Acer Aspire 3680 Laptop
How to change time
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Nov 06, 2008 | Panasonic KX-T7633 Corded Phone
Samsung NC10-14GW Notebook Logo
800 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
