Question about Food Mixers
We have a 5KPM50 315W Heavy Duty Stand Mixer. We still have 10 diff speed settings but the lowest setting now seems to run much faster. I have been told that it should be doing 60rpm on setting 1 but ours is doing approx 80rpm. It's about 3 yrs old and has been working fine until now.
  • neznosh Sep 08, 2010
    Is there any way to adjust the speed?
    Just a litte update, after ginko's comment I did a little more checking around. I found by winding in the top 2 screws on the control plate assembly I was able to reduce the speed back to 60rpm. Thanks ginko!
  • Food Mixers Master
  • 19,396 Answers
Hi.
If you are sure that the mixer is going too fast,
If the mixer has a speed control circuit,a then the on-board circuit may be defective.
If problem is only on a single speed, it may also be the speed selector.
To get a quote on repair Contact Kitchenaid:
Here also part list.
Posted on Sep 08, 2010
  • Ginko
    Ginko Sep 08, 2010
    Hi.
    You are welcome. If my comment was helpful, please do not forget to accept the solution. Your feedback is important to us.
    All the best.
    G.
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer motor noise at lowest speed
Hi,have you set you speed of your rotations,maybe it's set to slow.you have to Adjust the screws in the backof the mixer,so the rotation of the motor is a second apart on the speed setting three.i quite sure that's the right speed number,I have it written down somewhere,if I can find it and it's different il let you know.ty hopethatworks.
May 16, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Mixer works fine with speeds up to 6, but changing to 8-10, speed stays the same.
Sometimes can be caused by running too fast on the lower speeds. Should be 13 to 15 revolutions in 15 seconds on speed 1 then a slight increase only on speed 2.
Aug 01, 2013 | KitchenAid K5SS Heavy Duty Commercial...
K5SSWW Stand mixer started slowing down while grinding shrimp
I'm not quite sure about this answer but it occurs to me that it could be the governor. It sits at the back end of the armature and as the speed control is slid to faster speeds the governor moves away from its rest position pressing against the control plate. If the governor's pivots were to be binding, even slightly, it would explain the symptoms you are describing. A service manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 28, 2017 | KitchenAid K5SS Heavy Duty Commercial...
The kitchenaid k5ss runs at high speed at every setting of the speed control. How is this adjusted?
This is a bad rheostat switch. You will need to visit a repair center to have this fixed or get the part you need.
Mar 06, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Mixer won't shut off
Sounds as though the switch has shorted? Or the speed controller has failed ON. You could try a replacement if one can be had?
Feb 03, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KA Mod K5SS: no longer have variable speed; only 3 of the lowest
Hi. Go to mendingshed.com. Look up Kitchenaid Mixer Parts. Near the top of the page locate their FREE Kitchenaid Service Manual in Adobe format. Download it. This valuable document will help you with your troubleshooting of the speed control and anything else that needs fixing. This manual supports your K5SS. Mending Shed also carries Kitchenaid parts.
If you order parts from Kitchenaid, be prepared to wait at least a month for them to arrive!
If this solution has assisted you, please rate it. Good luck! ricardok45
May 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
There are no low speeds. Runs medium on "stir" setting.
see the solution at http://www.fixya.com/support/t501377-speed_switch_gone_beserk
Nov 04, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
107 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
