Question about Brother XL-5500 Mechanical Sewing Machine
Needle size replacement. I ran out of spare needle for my Brother XL-5500 sewing machine. Does anyone now the size and model of the replacement needle? thanks
    Genius:
  • 1,788 Answers
. Schmetz is excellent, Singer etc. Needles all work in the machines but most of your sewing will be done with an #11, but denim, for instance will be at least a #14, #16 depending on what you are doing. Buy an assortment of sizes, sharps for regular and ball point for knits, they are very inexpensive. Do not keep a dull needle in your machine, throw away old and start every new project with a fresh one.
Posted on Sep 08, 2010
Brother xl 2600 needle hitting feed dogs
Could be several reasons! Check that your needle is not bent, Make sure that you are using the needle is the needle size required BT specific machine. Make sure timing is checked by ttechnician.
Jul 05, 2014 | Brother XL-2600I
Thread skips
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 17, 2013 | Brother XL-5130 Mechanical Sewing Machine
Needle not catching bobbin thread at all
Did you change the needle? If that doesn't solve the problem then it's probably out of time. Take it in for repair.
Oct 27, 2012 | Brother XL-5500 Mechanical Sewing Machine
My top thread isn't picking up the bottom thread, and my needle is inserted right and not bent, i dont know what else it could be?
if you are sure needle is right then the timing could be off, sequence between needle going down and hook rotating around tocatch the needle thread. usually a tech repair.
Oct 13, 2011 | Brother XL-5500 Mechanical Sewing Machine
I couldn't find the Brother XL-3520, so I'll just ask here. I noticed that I have a single needle (already attached to machine) and a double needle attachment but I need a thicker needle for...
most domestic sewing machines use 130/705h system needles - buy a pack each of size 70, 80, 90 and 100 to start. if you plan on sewing knits (stretchy) fabrics then buy a couple packs of ball points in size 70 and 80. put in a new needle for each garment you sew as a needle goes blunt in about 6 hours depending on what you are stitching. visit www.sewing.about.com and check out sewing machines 101 and debbie's article on sm needles for more good info. depending on what your heavier weight fabric is you may need to use a 110 size to handle it. the denser the fabric the bigger it needs to be.
May 17, 2011 | Brother XL-3510 Mechanical Sewing Machine
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Brother XL-5500 Mechanical Sewing Machine Logo
120 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
