Question about Nokia E72 Smartphone
Unable to connect to server. please check the network connection
Unable connect server
Just switch off your router and power on again.
If the problem persists then try the below solution.
Go to
Control Panel\Network and Internet\Network Connections
In Local Area Network , check whether dns is set to automatic.
Aug 17, 2017 | Facebook Social Network
I am able to connect 80.0.75.60 server remotely ..in that i need to connect to one of my application server 80.0.75.62. i am unable to connect. actually servers are in sum other place. while pinging to...
The gateway at the remote end may be down. Ensure that the remote gateway runs fine. See whether the application server (80.0.75.62) has communication with remote gateway.
Sep 27, 2010 | D-Link DFL-800 Firewall
Error 81003004.......unable to login error showing ; check network connection
May be your Network Admin/ISP blocked your messenger port....Please contact your network administrator.....if you use socks proxy please clear the proxy from network connection>Lan Setting>Unselect Use Proxy Server.......etc. or check the Connection Preferences in the messenger window and select Connect directly to the internet and save....All the best
Aug 02, 2009 | Yahoo Messenger
It can't connect to servers.
I wouldn't recommend using a local connection for it.
Jun 18, 2009 | Sony PlayStation 2 (PS2) Console
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Nokia E72 Smartphone Logo
104 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
