Question about Speed Queen Washing Machines
I would like to know why Kinro in Pretoria is unable to find the necessary pipe to repair my washing machine? It is now about 3 - 4 months that the specific pipe has been on order from you. Could this be expedited in any way? Rachel Brummer
  • Speed Queen Master
  • 19,396 Answers
Hi Rachel.
Please contact Kinro directly calling (012) 804-9471.
If they cannot find the part you can try ordering online here: Appliance Parts.
Try Kinro first.
Regards.
Ginko.
Posted on Sep 08, 2010
Had my machine 5+ years, only used 3 times. Put water in today, switched on, there was a bang water came out of the main body. Power switch still lit but only warm. What's wrong
SORRY but with out knowing a lot more we could not begin to guess .suspect you had or still have a frozen pipe . can not fathom having a washing machine for 5 years and only using it 3 times .CALL A REPAIR SERVICE
Jan 06, 2018 | Washing Machines
Simpson 8.5 kg Eziset stops after wash cycle with error message E20. Am pensioner and unable to move machine. Machine is approx 4 months old. an you assist with advice pls.
If it's only 4 months old it should still be under warranty. Contact the place you bought it from and explain your problem to them. They should repair it at no cost.
Sep 17, 2014 | Washing Machines
Disconnect hot water pipe on washing machine
you need to shut the hot water off some were if you need to at the
hot water heater it's self
Apr 05, 2014 | Washing Machines
Empisal repairs south africa
Please could you let me know where i can have my empisal machine repaired - krugersdorp area
May 02, 2013 | Sewing Machines
Siemens washing machine keeps washing
Hi Linda Bailey,
If it keeps washing it could be that it is unable to progress to the Drain or Spin cycle. The likely culprit could be the Drain Pump Filter. To clean the Drain pump filter:
1) Plug the appliance out.
2) Open the small compartment below the door (Either Right or left hand corner) You will see a small pipe and a circular lid with a handle.
3) Drain the water by using the small pipe (Get a bowl for the water!), take of the cap of the hose or use the tap on the pipe on some models.
4) Once all the water is drained, open up the cap (Again.. Keep the bowl close by for spillage) by turning it anti-clockwise. Once off, clean the filter which is found on the cap.
5) stick your fingers into the now open compartment, be sure to clean out any obstructions, and feel if the impeller inside can turn freely.
THATS it! Now re-insert the cap, and close the pipe if open. Plug your machine in and viola!
It should solve your problem.
If not, let me know.
Kind Regards
JEDEMEYER1
Oct 03, 2011 | Siemens WM14S794GB Front Load Washer
Unable to locate the drain so that we can drain the machine. Can you advise where the drain olug is situated
Washing machines usually do not have drain plugs. Take the drain pipe and lie it on floor and let it drain into a flat container, this is the only way I know of draining a machine.
Mar 06, 2011 | Washing Machines
I have a kenmore top load washing machine model 110.92597200 that started leaking during the rinse cycle. The drain pipe isn't leaking and the water line hoses are just a few months old. They were both...
most likely is the water pump. you need to remove the cabinet to get to it and is at the bottom center. a white looking part. the shaft seal is bad.
Feb 09, 2011 | Washing Machines
Hotpoint washing machine is so loud
No this aint.. What is wrong with your machine is either the spider on the drum has cracked or your bearings are on there way out.. Not dealing with the problem right now will could be fatal... if you need any help let us know i do hundreds of these machines....
Jan 02, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
