Question about Lanzar Car Audio & Video
Nead a wire harnesfor modle # STVDN 7 - Lanzar Car Audio & Video
Hello, I nead a driver for my Verizon Samsung Gusto sch-u380 I nead it for Windows xp and Windows 7 Who can help me please
The best place to get drivers to enable you connect your device to your PC is the samsung support website. Visit the samsung support website from there you can download the driver for your device which will be compatible for both XP and windows 7.
Hope this solution has been helpful?
May 18, 2011 | Computers & Internet
Spinning but not getting hot
first you nead to use a meter to make sure you have 220 at the outlet.if you do than unplug the dryer and pull the dryer away from the wall so you can remove the back panal and the power cord cover.from the back of the dryer look to the right and you will see the heating tube.at the top of the tube you will see the high limit switch.remove the wires from the switch.use a metter to make sure the switch is closed. if it is open you nead to replace the switch.if it is closed than you nead to look down the tube and you will see the next high limit switch. remove the wires from the switch and check that it is closed.if it is open than replace it.if it is closed than under the switch you will see the heating element.remove the wires from the heating element and check the element .if it is open than you nead to replace the element part#3403585.
Jan 16, 2010 | Whirlpool LER4634J Electric Dryer
Agitator not working properly...lower part works while the upper part just sits there not turning
you nead to replace the dogs in the top portion of the agitator.first remove the fabric soffiner despencer from the top of the agitator,next there may be a plactice cover that you nead to remove,next you nead to remove the 7/16 bolt and pull up on the bottom of the agitator and remove the agitator and place it on the floor,put a foot on both sides of the bottom of the agitator,next you nead to grab the top of the agitator and pull up and remove the top of the agitator.place your hand inside the top of the agitator and turn it upside down and remove the dog assembly.replace the rubber dogs and reassemble the agitator and reinstall the agitator.
Dec 31, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My REX4834KQ dryer will start, but doesn't get hot. It also will not turn off automatically anymore!
first make sure you have 220 going to your dryer.in alto cycles the timer will not work if the heating element is not working.next you nead to remove the back panal and the power cord cover.if you look to the right you will see the heater housing.at the bottom you will see two wires going to the heating element.remove the wires.with a meter check the element to see if it is open.if it is than the element is bad.part#3403585 if not than we nead to move up.check the next high limit switch to see if it is open.if it is than it is bad.next we nead to go higher to the hi-limit tgermostat at the top of the heater housing part#3977393. if it is open than you nead to replace it.
Dec 09, 2009 | Roper REX4634KQ Electric Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
I have a Kenmore special edition model # 110.63912100 (S/N ML350387S) that will not heat. What do you suggest, heating element, thermostat, or ???
first make sure you have 240 going to the dryer.you will nead a meter check this.if you have 240 ,than you nead to unplug unit.pull unit out and take back panal off.on the right side you will see the heating colom.at the top is one of the high limit switch's.you will nead a continueaty meter to check this.at the bottom you will see the other high limit switch.make sure you unplug wire's before you check them.under thst you will see the heating element.remove wire's and check out element.also look for bad wiring.if all check good, you nead to call for service call.
Nov 16, 2009 | Kenmore 62802 Electric Dryer
My Roper dryer won't start?
first make sure you 220 going to you dryer.next you nead to unplug the dryer.next you nead to remove the vent hose.next you nead to remove the back panal and power cord cover.on tge lower left side you will see a white plastic switch with two blue wires going to it.this is the thermal switch.if you use a meter and the switch is open tha you nead to replace this switch.part#3392519
Nov 11, 2009 | Roper REX4634KQ Electric Dryer
I NEAD A NEW FRONT END . WHICH OTHER MODLES WILL INTERCHANGE WITH MY 2004 FXD
any 2000 to about 06??? (check with dealer to find the exact cut off year/month)Sportster, SuperGlide or SuperGlide Sport will pretty much be a bolt on with minor wiring and hose changes. You can put just about any front end on it if you are inclined to make the needed changes, but for quick and easy (stock) stick with Sporty and SuperGlide.
Oct 22, 2009 | 2003 Harley Davidson FXD Dyna Super Glide
Model # is LSR8233EQO Top portion of the agitator seems loose and does not agitate properly?? Does is remove? It seems to unscrew??
you have to replace the dog's in the top ov the agitator.the part# ror this part is WPL80040462.the cost is $4.62.to replace the dog's you nead to remove the fabrick sofeiner assembly from the top of the agitator.next you nead to remove the top cap.now you nead to use a 7/16 socket to remove the bolt in the agitator.now you nead to grab the agitator at the bottom and pull it up.now yopu nead to seperate the top from the bottom.place the agitator on the floor,put a foot on both side's of the bottom of the agitator and pull up.now you the top portion of the agitator.turn top portion upside down and remove the cam.you will see the rubber dog's.replace the dog's and reverise the prossess.
Oct 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Car Audio & Video Logo
21 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
