Question about Asko 24 in. 1805 Built-in Dishwasher
Trying to pull out dishwasher from countertop but it just wont budge! even opened the door and gave it a good tug but no luck! help
  • Asko Master
  • 43,501 Answers
Did you remove the screws from the counter top??? Usually they are held in by a couple of screws through tabs at the top of the dishwasher...open the door and then look up...
other then that I would have no idea what is holding you fast, unless the water supply in coming up through a hole directly into the solenoid valve and holding you...
heatman101
Posted on Sep 08, 2010
Should the steam vent on top of Kitchenaid dishwasher be visible when door is latched or should it be jnder countertop completely?
unless you have a granite countertop I would say it needs to be seen wood getting steamed will rot out rapidly
Jan 16, 2016 | KitchenAid Dishwashers
Having great difficulty opening the dishwasher. no real lever to open.
That's some pretty sketchy information to try to base an answer upon, but having just installed a DW and encountered a similar issue, let me offer this.
While I was doing my install, I encountered difficulties with an uneven floor, semi-rotten floor and subsequently, leveling the front leg adjusters was a challenge. At one point, substantial differences in the adjustments caused the entire body of the DW to become slightly distorted from "square", resulting in the symptoms you describe.
something to check!
Sep 28, 2014 | Whirlpool WDF750SAYM Gold Series...
Door wont open on Hotpoint WM51 First Edition
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Apr 25, 2013 | Washing Machines
GE dishwasher - my daughter sat on the door and it opens too far now. Which part needs replacing?
Here's a try.
You need to pull the unit out from the hole it's in so you can examine it.
Most installations have only two screws holding the two tabs to the counter at the top front.
Open the dishwasher door, and look at the very top and see if there are two screws holding the dishwasher to the countertop. If so, remove them.
The dishwasher should now pull out of the hole it is in, BUT, pull it only about halfway out, because there are several connections you do not want to break.
There is a wire hookup, a drain hose hookup , and a feedwater line hookup.
I'm hoping you can do this without disconnection all that.
Try opening and closing the door and see if you can gently bend the metal arms to make it better, or identify what is needing replacement.
Get on your computer or someone else's and type in Sears Parts.
Sears offers free schematics online that will show you pictures you can blow up to any size for any machine.
You will need to take the make and model from the plate on the door or the body of your dishwasher to get the right schematic.
If you need to order parts, many places on line sell them.
Good luck with your efforts.
Jan 07, 2013 | GE Dishwashers
Hi i'm having a problem with my adidas pro white low cut sneakers i just purchased the color inserts wont come out i've tried pulling them out they wont budge at all please help hoew do i get these...
Dont pull themat the heel or you will be in a tug of war. take them out at the arch and it is a lot easier. Lift the heel out and then pull the toe out.
Jul 28, 2011 | Adidas Pro Model 08 Basketball Shoes
Went to open my dishwasher and the handle came off, now I cannot get my diswasher open.
Hi
Try to put the handle back in correct position and then give a gentle tug on the door. If this will not help then it can be opened by pushing on either side of the vertical center tab in the door opening and then pulling on the door, this will actually release the actuator mechanism. After this is done the handle should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 16, 2011 | EuroTech Dishwashers
Can't open door
get a coat hanger or flexible wire and try to run it under latch from the top. This may be difficult depending on how your countertop is. Once it's under the latch from one side to the other, pull up on both sides of wire to raise the latching mechanism. Open door.
Oct 24, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher door won't latch closed
Please tell me, did you find out what's wrong - because this has happened to me now. :(
Aug 28, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Asko 24 in. 1805 Built-in Dishwasher Logo
57 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
