Question about Gigabyte GA-945GZM-S2 Motherboard
How to connect the power supply cables to motherboard?
  • 73 Answers
Accordhttp://webcache.googleusercontent.com/search?q=cache:cn4FgQtjuTgJ:www.intel.com/support/motherboards/desktop/sb/cs-020836.htm+how+to+coonect+power+supply+with+945+moter+board&cd=1&hl=en&ct=clnk&gl=ining to *********** board.................this link wil hepl you.
copy and paste above link on the web browser. and get your solution.
JAIN_IT
Posted on Sep 08, 2010
New GA-990AX-UD3 motherboard will not boot
You really should take that Power Supply, and use it on grandma's computer.
The 8-pin EPS +12 Volt power cable was brought out, to provide more power To the motherboard AND processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
The 4-pin ATX +12 Volt power cable has TWO yellow wires.
Yellow wires are 12 Volt wires. (And two Black ground wires)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The 8-pin EPS +12 Volt power cable has FOUR 12 Volt wires.
In the motherboard manual, does it say, "Yes Tom. Go ahead and use a 4-pin ATX +12 Volt power cable. We don't care. We just use an 8-pin EPS for fun."
[ This is an 8-pin PCI Express power cable. Completely different,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8 ]
The motherboard probably uses 150 Watts by itself.
No Ram Memory, no CPU, no fans, etc.
The CPU could use up to 125 Watts of power. Just depends on what AMD, socket AM3, processor you are using.
Now to graphics card's power;
The most Wattage a PCI-Express x16 slot can deliver is 75 Watts.
The most power a 6-pin PCI Express power cable can deliver is 75 Watts.
8-pin EPS +12 Volt power cable? 150 Watts.
When buying a Power Supply you should calculate all components needing power,
http://extreme.outervision.com/psucalculatorlite.jsp
,then buy a Power Supply that has AT LEAST 10 percent more power than needed. Easier on the Power Supply.
Also a computer will NOT use more power than it needs.
10,000 Watt power supply, (Exaggeration ), and the computer only needs about 100 Watts for surfing the internet?
Computer ONLY uses 100 Watts.
Due to the price, the above, and the availability, you should use a 500 Watt power supply at least.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&CatId=1079
http://www.amazon.com/StarTech-6in-Pin-Power-Adapter/dp/B002O21XHQ
Or use it on yours if it has enough Wattage.
Back in the day, the motherboard didn't need to supply that much power to components on it.
More powerful Processors, Ram Memory, and graphics cards, brought the power needed, up.
A 4-pin ATX +12 Volt power cable was added for the motherboard. Then 6-pin PCI Express power cable for graphics cards. Then the 8-pin PCI Express power cable for graphics cards. Lastly the 8-pin EPS +12 Volt power cable.
(Better make sure the Power Supply you have is good, if you wish to use the above power adapter cable. Nothing like having a Power Supply with a weak voltage power rail, and a new build, to pull your hair out on )
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
Out of the motherboard manual Page 23,
"With the use of the power connector, the power supply can supply enough stable power to all the components on the motherboard. Before connecting the power connector, first make sure the power supply is turned off and all devices are properly installed. The power connector possesses a foolproof design.
Connect the power supply cable to the power connector in the correct orientation. The 12V power connector mainly supplies power to the CPU. If the 12V power connector is not connected, the computer will not start.
To meet expansion requirements, it is recommended that a power supply that can withstand high power consumption be used (500W or greater). If a power supply is used that does not provide the required power, the result can lead to an unstable or unbootable system."
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2012 | Gigabyte Technology GA-990FXA-UD3-...
How to connect400w ate power supply to cpu
Simple change. Just turn the computer off, remove the power cord, open the case. There are 4 screws that hold the power supply in place that you will have to remove then you can remove it. What where the cables are connected to the motherboard from the old power supply because you want to connect the cables from the new power supply in the same place.
Normally there will be two cables that plug into the motherboard and they will only fit in the correct place on the board. There will be a number of cables for the hard drive and dvd drive and it doesn't matter which one you use.
Jun 06, 2012 | Dell Computers & Internet
Computer does not switch on
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
All the best
Aug 04, 2011 | Packard Bell Computers & Internet
Where do I connect the SATA power cable to on the motherboard
Only the SATA data cable connects to the motherboard, the SATA power cable is connected to a cable from the Power Supply Unit (PSU) if you do not have any of the SATA power cables on your PSU you can get MOLEX to SATA power cable converters (MOLEX is the "fan power connecters")
Mar 28, 2011 | Intel Motherboard
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
I have a problem with my pc it will not boot up it starts to boot then just turns off I cant get and diag done to troblem shoot the problem PC specs Win XP sp3 3gb ram DDR2 Celeron D...
now, this sort of shut down is difficult to diagnose on remote, i would suggest downloading your motherboard manual beforehand. before you do anything, i would suggest read in manual where is reset pin and how to reset bios to original state, but do not do that yet, it will lost all your mods settings and return m/b - bios to original state. there are several possible causes of that fault.
1. faulty memory stick
2. thermal or fault on power supply
3. thermal or fault on motherboard
4. corrupted bios
we will start with easiest to check re 1.
a. switch off your computer,
b. remove power cable from power supply,
c. remove side wall,
d. remove memory sticks and replace them with known working ones from another computer
e. reconnect power supply and switch computer on, if computer works correctly, you solved your problem and need to replace memory sticks
power supply is not much more difficult re2.
c. remove power supply cables from motherboard and all accessories, do not remove power supplly from it's craddle yet
d. connect cables from new power supply to your motherboard and processor fan, connect them to your hdd and cdrom,
e. connect power cable to new power supply and start your computer, if computer run correctly, switch it off, remove old power supply and replace with new one
most tiddly bit... when you arrive here that meant that previous two did not solved your problem, re 3:
c. disconnect all cables from your m/b
d. connect power supply to m/b and processor fan
e. connect ps2 keyboard
f. connect monitor if "all in one" m/b, video card and then monitor in any other case
g. insert power cable to power supply
h. switch on your computer
i. acess bios (that is usually done by tapping "delete" key, find in your manual) if possible, if not then:
i1. switch off power supply
i2. remove power cable from power supply
i3. re-set bios (you need to locate reset pins/switch/button on you motherboard in manual)
i3. reconnect power supply cable \
i4. switch on the computer
j. acess bios and set your thermal to 75centigrade or 80 centigrade and 5min
k. close bios saving changes
l. re-boot your computer and leave it for 10min, if computer still run, that will indicate your problem lies elsewhere.
checking auxiliaries:
c. connect cd-rom
d. reinstall power cable and re-start your computer
e. allow 10min run and check if computer is still running
switch off. remove cable and connect your hard disk drive, run or switched off? if off, you need to check your hdd...
any other auxiliaries need to be connected again in steps and if finaly you find one which terminated boot up, this meant that this particular element is responcible and need replacing. you need as well consider that your power supply maybe perfect on the bench, but will be too small for load required adn simple upgrade to more powerfull mother board can solve the problem.
hope that half book on problem solving solve yours :-)
Jul 30, 2010 | Computers & Internet
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
Dell 4700c will not power on white light on motherboard
Is there any chance for you to check if the power supply blows air from inside of the power supply? If yes, on your motherboard, do disconnect the P1 cable or the main power supply cable that connects to the motherboard and the P2 cable which. and try to plug the power cord of the power supply and if the fan did not spin, power supply is the one causing the problem
You may also try to remove the RAM or memory card module from the motherboard and all of the PCI card connected to the motherboard. Try to turn on the system and check the power supply fan and the CPU fan if it will spin. If not then I recommend you to replace the power supply.
On the other hand, if the fan is spinning on the power supply after you remove all the RAM and PCI cards. And the power button light is flashing amber or solid amber color. Try to install RAM 1 by 1 to isolate the problem.
Let me know if the problem persist
I
Sep 23, 2009 | Dell Dimension 4700C PC Desktop
Power supply
this is infact your video card and it can be the power supply if the burnt cable is connected to ur video card
the monitor is fine but about the burnt cable on your power supply
make sure you buy electrical tape and tape that up as soon as possible because if that burnt cable touches any part of your motherboard or anything else it will instantly fry everything which means damage everything which means ...
on the worst case scenario that has already happened
Sep 26, 2008 | Foxconn 761GXK8MB-RS Motherboard
Gigabyte GA-945GZM-S2 Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
