SOURCE: dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
SOURCE: Dell 1815dn all-in-one-laser
There is a little tab that locks the scanner bar.
Open the flatbed cover, and you'll see it in the left corner closest to you.
To unlock it, reach your hand (palm up) into the area the the paper comes out in.
Slide the tab to the unlock position (you'll be able to see it through the flatbed area.
If you need a complete manual for the MFP, you can go to the Dell website, in the support area, and download a copy of it.
SOURCE: scanner locked printer dell laser mfp 1815dn
The lock for the scanner is on the roof of the cavity where the printed paper comes out. Simply flip it to the other position and restart the printer.
SOURCE: I accidentally pushed the lock blue bottom on the
Pull it toward you. You may have to pull kinda hard, but just pull it back. It's sole purpose is to lock the scanner head during shipping.
SOURCE: I cannot unlock my scanner? Dell 1815dn
The scanner has a manual lock (a blue sliding switch on the base of the scan bed inside of
the printing output slot.)
This prevents the scan head from damage when the printer is moved.
Look and reach inside the paper outlet and pull the latch (located on the left) towards you.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
