Question about Husqvarna 160 CC Honda OHC Engine 21 in
Honda HRG465C3 After having unscrewed the 4 screws of the valves cover, no way to remove the cover ! Do you know how to proceed ? Many thanks Marcel Bucci
    President:
  • Husqvarna Master
  • 1,545 Answers
I tap on stubborn items like that with a rubber mallet. It doesn't ever hurt the parts and does the trick.
Posted on Sep 09, 2010
WE HAVE A NEWHOME 550WL DL GAS COOKER. I DONT KNOW HOW TO TAKE THE GLASS OFF TO CHANGE THE BULB. THE GLASS IS SQUARISH, BUT THERE ARE NO SCREWS.
Taken from the User Manual.
Remove the oven shelves. Remove the loose oven back by unscrewing the 4 securing screws (one at each corner) and remove (Where fitted). Unscrew the lens cover by turning anticlockwise. Remove the bulb and replace. Replace the lens cover and oven back.
Jan 18, 2018 | Kitchen Ranges
How do I adjust the valves on a 2004 Honda 400 RancherTRX FGA?
If you are talking back lash yes you have to get to them by removeing the valve cover .
Make sure you know what the hot and cold clerances are and ware you slide the feeler gauge in makes a difference and the order you adjust them also makes a differance .
I would check with Honda this information is free .You over thghten an ehxuast valve its a spent engine
Mar 26, 2015 | Honda 2004 FourTrax Rancher 4X4
Magnetic Valve Assembly Part Number: BES820XL/198 leaks
Step 1: Unscrew back cover (4 torx screws and 2 phillips screws) and remove.
Step 2: Slide top warmer forward (may have to force with palm of your hand) disconnect ground wire.
Step 3: Remove valve assembly. While standing at rear of machine it is located in the rear upper left corner (on a 830xl), remove 2 phillips screws and disconnect wires taking note where they are connected. Remove split castanets from conecting tubes (push on one side then slide them off) making sure to also remove grommets.
Step 4: Instal new safty valve assembly reconect all disconected tubes with excisting grommets and reconnect all wires.
Step 5: Remount assembly with screws, reconnect wire to warmer top, slid backward into place and replace back cover with screws, connect to power, fill water tank and turn on.
Oct 16, 2012 | Breville Die Cast 800ESXL Espresso Machine
I have a panasonic microwave oven model # nn-h965wf which has a bad inverter board. how do you replace it
if your unit is attached to the kitchen your need to use the screwdrive for to loose and remove the microwave.
2)proceed and open the carcase and see the screw inside of the board
3) caution can be there to due the magnetron (valve electronic), and proceed to unscrew with screwdriver and take out the board.
4) proceed in contrary sense.
5) Proof., remember you must to unpplug the power before to do anything.................. CAREFULLY.
Jul 11, 2012 | Microwave Ovens
1992 honda accord 2.2----- 4 cylinder engine-how do you change valve cover gasket?
To replace the valve cover gasket, you have to:
1) Remove spark plug wires
2) Remove spark plugs
3) Remove ground cable, and all pcv lines and hoses
4) remove 4,10mm nuts holding the valve cover on
5) remove valvecover, and replace old gasket
I hope this helps
Matt
Jun 16, 2011 | 1992 Honda Accord
How to remove the pcv valve from a 2006 pt Cruiser Turbo 4-cyl
Hello! The PCV valve is threaded into the right side of the cylinder head cover...Remove the hose...Unscrew the valve...
Guru......saailer
Jul 02, 2010 | Cars & Trucks
How is the backup battery charged and or changed
Remove top (side thumbscrews)
remove main battery cover and battery
unscrew stylus holder from back (1 screw)
unscrew black plastic inner top (4 screws)
remove top gasket
unscrew back (6 screws)
carefully remove back
CAREFULLY NOTING THE POLARITY OF THE PLUG:
carefully unplug connector from back
unscrew plastic cover over the speaker & backup battery from inside of back cover (4 screws)
replace battery w/ Digikey #P084-ND
23x2mm 3volt 30mah lithium battery ~$6 USD in 2010. aka Panasonic #VL2320/VCN
this requires you to re-solder the ex. leads to new battery*
*WARNING ASSUMES YOU ARE ABLE TO CHECK THE POLARITY AND KNOW HOW TO SOLDER SMALL ELECTRICAL COMPONENTS.
YOU ARE ON YOUR OWN HERE AND ASSUME THE RISKS THAT THIS TYPE OF GADGET HACKING ENTAILS!
(Optional - find an original replacement battery from Panasonic with the correct leads attached and just plug it in. This is much safer.)
Reverse operations and you are back in business.
Jan 26, 2010 | Panasonic Toughbook CF-P1
How to replace driver side window 97 4 door honda civic
normally on the honda2.gif models there are two screws that need to be taken out, the inside latch area (plastic cap covering it) and the door pull (normally down in the bottom covered with a plastic cap), thin small flat blade will work to remove. once the is done you will need to pull out the latch area on the driver's window control panel, disconnect the connectors. set the aside, next you will need a thin flat blade screw driver or flat pry bay, start at the bottom of the door to pry out the panel, check for screws, if you cannot see any proceed to using the flat blade to remove the panel (will make a loud snapping or popping noise, this is normal) once you have loosened the panel, you will need to remove the plastic covering the access to the mirror (small triangle black plastic piece). this should now allow you to set the door panel aside, check to make sure you have removed all the clips. carefully remove the plastic lining cover the door, try not to tear or rip it. now you will need to remove the glass, there are two holes the allow access to the bolts for the window, connect your Power window switch and raise or lower till you can see them ( possibly a 10 mm socket) unscrew and set aside, hold the top of the window with one hand and lower the window to separate it form the brace. tilt the front side of the window down and remove glass set aside, replace your new window and re assemble as you have taken apart, most cases this is about two hours, Good Luck !!!
Jul 07, 2009 | 1997 Honda Civic
How do you remove the cover panel to take out the radio on a 94 handa accord ex
Open up the armrest and in the bottom you will find a cover. Pry open this cover with a flathead and remove the two screws found at the bottom. Then remove the cup holder and unscrew the screw in the front corner on the left side(if sitting in the drivers seat) and ignore the two screws on the bottom of the cupholder. Now you can remove the armrest unit. Next, unscrew the two screws now visible after removing the armrest. Once these screws are removed you should be able to pop the plastic cover off from around the radio and components.
Jul 05, 2009 | 1994 Honda Accord
CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Mar 18, 2009 | EliteGroup ECS DESKNOTE A929 Notebook
Husqvarna 160 CC Honda OHC Engine 21 in Logo
91 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
