Question about ASUS P5PE-VM Motherboard
No display but the processor fan is running. - ASUS P5PE-VM Motherboard
  • ASUS Master
  • 27,725 Answers
Test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 08, 2010
Dell inspiron 2020 all in one fan problems
I have found that if the room temperature near the computer is too high creates a problem. If the processor is being used at a high rate that will influence the temp sensors and cause the fan to run at the "speed" you hear. (It is on all the time, just different speeds). Other heat producers may not have clean fans or fins, for example display adaptor or power supply. or but unlikely, the
cpu fan interface is not well seated or no heat transfer grease. You didn't change the processor did you?
Apr 05, 2015 | Dell Inspiron One 2020 Desktop Intel Core...
No Beep no display: Cpu fan Running.
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Dec 29, 2010 | ASUS P4VP-MX Motherboard
Lga motherboard no display, processor doesn't heat
if your processor does not heat up it's probably dead.. try running it without the fan and see if the heat sink still doesn't heat up
Sep 07, 2009 | ASUS P5V800-MX Motherboard
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
REPLACED MOBO INTEL D845EPI/845GVSR EMACHINE 2.5 P4 REPLACED PROCESSOR... NO DISPLAY OR KEYBOARD RECOGNIZED, NO BEEPS NOTHING BUT FANS ARE RUNNING AND LIGHTS ARE ON?
1.*********** Board not supporting Your Processor.
2. Try With Lower Speed Processor
3. Mahe sure that Mother Board is Working or Faulty.
4.Check the ram twice
If it HELPS RATE ME!
Jun 24, 2009 | Intel Desktop Board D845EPI Motherboard
No display loose connection between processor and motherboard
open ur cpu and check connection of processor and clean the RAM
Apr 28, 2009 | Intel Desktop Board D845BG (KD845BGPAK10)...
2 ghz processor running at 220 mhz
Have you tried right clicking on the desktop (opening Display Properties), clicking on Screen Saver tab, Clicking the Power button, and setting the power schemes to Home/Office Desk? If its set on laptop it will reduce the processor speed when running on battery. I have noticed that even with it plugged in that some times it will run at half processor speed. Try that out.
Have a great day,
Armymason
Mar 02, 2009 | Dell Inspiron 9300 PC Notebook
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
My mother board
hi icebox143ph,
just insert ur proceesor in ur motherboard if processor fan is moving than the motherboard has minor defect i.e display problem if processor fan is not moving than the motherboard ic has burn
Mar 06, 2008 | Foxconn WinFast K7S741MG Motherboard for...
ASUS P5PE-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
