I am having seaget 320GB Harddisk, which is not detected in BIOS, but when checked it disk is moving. I am having critical data in Hard disk which I need to recovery. Please help.
    Novelist:
  • 150 Answers
I am assuming that your hard drive is internal not external. Turn off the machine. Open the case and unplug and plug back in the connector(s) from the hard drive one at a time. Do this to both ends of the cable. If it is an SATA drive, you will have to squeeze the connector to get it to release. Close the machine up and turn it back on.
If this does not fix it, try taking the hard drive out and putting it in another computer. If it works there, the BIOS/Motherboard is bad on the original machine. If the hard drive does not work in the other computer, then it is likely that the electronics board on the drive is shot. You will have to take the drive in to a computer shop or send it somewhere to have the data recovered. That can get expensive. They will put a new electronics board on the drive to read it out. They will really gouge you.
There are utilties that you can try to download to a good machine, attach your bad drive to the good machine as a "slave", and run the utilities. That may or may not work to recover the data if the drive is screwed up but the utilities require a certain degree of expertise to work correctly and if the drive is not recognized at all, then they will not work.
I know you don't want to hear this, but backup, backup, backup.
Posted on Sep 08, 2010
  • 32,281 Answers
If the BIOS does not detect the hard disk then the hard disk could be faulty.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services. The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
First thing I would try is to remove the damaged hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
It wont rocognise the hard disk but will pick up everything eslse
Change ide or sata cable.
Also change power cable of smps to harddisk.
Make sure your harddisk set as master with jumper settings.
Read jumper settings on harddisk then set harddisk as master.
Then check in bios.
Change ide or sata ports on motherbord then check.
Nov 17, 2009 | EliteGroup K7S5A Pro Motherboard
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Sep 17, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Harddisk not detected in disk management but recognized in bios
Does it show in the devices? If it is, check and see if it is disabled. If not, check the jumper settings on both drives, and check your bios settings.
Sep 02, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
After two years of use, no BIOS beep and nothing on screen.
Open cpu cabinet Reattch all connection to harddisk power cable and sata or Ide cable.
Then Pull cmos cell from motherbord chipset for 10 minutes so all bios settings are defaults.then Power up the computer press "del" or F1 or F2 to ente rin bios then check your harddisk is detected or not.
arddisk must detercted in bios for boot.
Also set first boot device as your harddisk.
then save settings and exit.
Aug 15, 2009 | Computers & Internet
Hard disk not detected but Cd Rom drive detected
reconnect data cable or sat cablew to harddisk
Aslo reattch power cable to it.
Then check in bios that if u have sata then sata must enabled in bios.
May 22, 2009 | Seagate Barracuda 40 GB Hard Drive
Bios Upgrade so to recognise new 320GB size Hard Disk Drive
first check jumper settings in harddisk.
also check there is no unpartrtioned space.
right clik on my computer then go to manage
then go to diskmangement
If there iks any unpartitioned sapce of 184 gb then create partition.
Mar 26, 2009 | Computers & Internet
Bios not detecting bootable harddisk
Repair windows xp using bootable windows xp cd..
Mar 09, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
SATA's compatibility , motherboard update?
Hi k439,
Keep in mind that all serial ATA SATA hard disk drives are seen in the main bios menu as a Primary Master drive. When you load the bios you should see the SATA 320GB drive in the main menu, Standard CMOS Features. If you do not than the onboard SATA controller is defective. This can not be repaired. Only a motherboard replacement will fix this issue. You can go to MSI's web site below & allow MSI to check you're system for the latest bios upgrade. Follow their online instructions & update you're bios file but this will not fix you're onboard SATA controller. Click this link to MSI Live Update link: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
Sorry k439
Mike
Aug 16, 2008 | MSI PM8M-V Motherboard
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
