Question about Whirlpool Ovens
Dear Sir/Madam This morning the oven was not working no lights was like it was switch off. i wonder if there is a fuse anywhere. i haven't got the manual so I do not know where is the connection to the mains. Could you let me know what should I do Thanks Regards, Jose Franco
  • balanco2004 Sep 08, 2010
    The Oven
    MOD: AKZ104/1X 2.4KW TYPE;: FCEM6
  • Whirlpool Master
  • 1,711 Answers
Could you let us have the type and model of your oven so we can be more specific
Posted on Sep 08, 2010
  • espressonist
    espressonist Sep 08, 2010
    There is not any internal fuse in the oven. You have to check the socket fuse or the circuit braker from the mains for the oven. If it is off replace or switch on once.
    If it is off again that means you have a short curcuit on your oven which mean that you need an electrician or authorised technician must check for the fault.
    One thing you can check before call them is to check the lamp which it might burn hard and cause the problem.
    The instructions for replacing the lamp you can find in the user manual and since you dont have it you can download from this side
    http://www.whirlpool.eu/eu_EU/european_h...
    chose the required country and add your model and laguage and you can download the pdf file.
    In the manual their is istructions and photoes how to replace the lamp and is a dood idea to check them out before call for service.
    Good luck
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
My Delonghi EST461 ST oven has stopped working. The grill and fan work but the oven does not, it initially tripped the fuse. Any suggestions
always turn the power off first , you will need a flash light look carefully around the bottom element , I think it has burned out on you , it will have a bump or burned spot on it or may even be broken off , this is bery easy to replace and cheep if you find it is burned or broken off email all info on oven make, model, serial number I will locate the part and tell you how to replace it Have a nice day !
Dec 06, 2011 | Ovens
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Can't find the fuse for the oven
I doubt this is a fuse problem. Could be the heating element has failed.
Apr 21, 2009 | Ovens
Vent fan stays on
The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
Switch problem?
click here sir
there select range/stove/oven
in that select switch
after doing that see for the 3rd part.
this is the light switch you need.
replacing it is not very tough. but it is not that easy also.
since you are going to work near circuit boards this must be done carefully. if any small mistake will cause more problems.
everything depends upon your expertise sir.
thank you
Aug 15, 2008 | Dacor MCS130 Millennia Electric Single...
No power to heating coils
h\ave you check for any damaged ono the themal fuse..?
Jul 09, 2008 | GE JTP45 Electric Double Oven
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Ovens Logo
23 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
