Question about Mitsubishi WD-65733 65" HDTV
Hi, my 4yrs old MITSUBISHI DLP 64 INCH TV will not come on any more came home and no response i'm wondering if its the fuse or is it the lamp any ideas help please
It does no come on an want to know if it a fuse or the lamp
Posted on Jun 01, 2011
Mitsubishi dlp wd-65638 with error code 61. What is this error code? How do I fix? no picture or audio.
if the power LED is flashing green then there is a circuit or board that either has a blown fuse or relay. if it comes on solid red when you turn on the television then the Lamp inside is burned out and needs replaced. Before you spend all the money that changing the bulb would cost i would invest that money in a good LED Smart TV instead. Sometimes you just gotta let that old technology go away.
Dec 30, 2014 | Mitsubishi WD-65638 65-Inch 3D-Ready DLP...
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
82" Mitsubishi DLP tv Picture Blinks every few minutes
your Lamp is on the Way out. You will need to replace this in the Next 4 months, This is the First sign of the Lamp failure. How old is the TV?
Nov 10, 2013 | Mitsubishi WD82738 82" inch 3D Ready DLP...
When i turn on my 64inch mitsubishi wd 65733 tv it stays on for about a min (WITH PICTURE AND SOUND)then it just shuts off with the (orange) status light steady and the (green)lamp light blinking. I cant...
My concern is that the new lamp may be having an issue and not able to hold the high voltage.
If the old lamp was working, I would try this old lamp again.
If this issue was with the old lamp also. Then there is something else wrong either in the power supply or the lamp ballast where it isn't able to continue to put out the high voltage.
More than likely a lamp issue!
A/V Media Tech Guy.
Feb 02, 2010 | Mitsubishi WD-65733 65" HDTV
Lamp Indicator is Red
Its much more likely that your getting a 34 error which is a lamp abnormality vaused by defective capacitors on the power board. You can get the V26 DLP power PWB repair kit at the following link that should repair the issue. Chances are your old lamp is still good.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
May 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
My Mitsubishi 65 inch DLP will not turn on. I tried to turn it on last night and the tv seemed to power up but no picture was present. I tried to reset, and the same thing happened. I pressed the Menu...
looked up owners manual that was a waste of time, hmm the number one issue on this type of set is issues with the lamp. How old is it? Has it ever been replaced? Sometimes a visual inspection of lamp can fool you, but typically as they age a milky haze develops on the lamps glass or if it popped the lamp will be shatttered inside. Can't hurt to check it. make sure set is unplugged first just to be safe.
Apr 30, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-65733 65" HDTV Logo
307 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
