Question about HP 1200W 12V 48VDC Rps for DL380 G5 DL385 G2 Power Supply
HP DL380 G5 Server - Intel Xeon 1.87 Ghz, 2 GB RAM, 3 X 146 GB SAS with RAID-5 configuration, RPS P-ID - 417454-371 S/N - SGH647Y3RH O/S Installed - MS-Windows 2008 Server ? STD Ed. 32 bit with Active Directory Problem - Today in the morning server was working fine. Suddenly very loud fan sound came continuously from system with no display. After 5 mins I turned off the system by pressing power on button for more than 5 sec. After 30 mins when I turned the system on, the same sound came through server continuously with no display. No indication is giving on front panel indicator of server. I removed RAM, Raiser card, memory and re-fixed it and again tried the same, but same result. Next day when I come and start the server, it starts for about 15 mins. After that same problem.
Heat maybe?
try to cool the monster. Let the air flow
Posted on Nov 02, 2012
  • giannns
    giannns Nov 02, 2012
    heat maybe?
5 Suggested Answers
dodgecharger
  • 254 Answers
SOURCE: pc no start.........
You might have a bad power supply. If you have a voltmeter, check the voltage of the standby power supply. This voltage is present even if the system is off, plugged in. It powers a small portion of the logic circuit. It should measure within a couple of tenths of exactly +5 volts. If it is low, or high, this will prevent turn-on. The purple wire of the 24 pin connector is what carries this to the motherboard. The color coding layout is found at http://pinouts.ru/Power/atx_v2_pinout.shtml If by chance this voltage is OK, then check the full on voltages also. Repair of the defective supply is probably by replacement of one or more small electrolytic capacitors in the appropriate circuit, especially if you are technically savvy. Capacitors are available through several suppliers; Digi-Key supplyies Panasonic FC series which are suitable for switching power supplies. Or, you may just replace the whole unit.
Posted on Apr 25, 2007
techman
  • 3130 Answers
SOURCE: hp d220mt
Take the ram back out of the computer that you just installed and see if you have the same problem. If you do, a board or plug must have came loose when you were inside the unit. If the problem clears up, the ram you are trying to use is bad or not compatible with your computer. All ram is not alike. Good Luck
Posted on Nov 12, 2007
DickCanFixIt
  • 948 Answers
SOURCE: Loud Humming Noise from P/Supply
Yes, it is time to replace it. Open the case and make sure it is a standard size before you buy another one. Just measure length, width & height. You can put a higher wattage supply in there, it just won't have to work as hard to power your computer.
Posted on Apr 07, 2009
  • 36 Answers
SOURCE: Hi, I have a pavilion 516x desktop, it seems my
are you sure you have connected all cables to the power suppy, or then your motherboard has crashed. hope this helps
Posted on Mar 26, 2011
Hp proliant dl380 g7 (raid 5 with 3 H.D.D)error non-system disk or disk error replace and strike any key when ready
Turn the computer off.
Unplug its power-cord.
Connect its power-cord.
Turn the computer on, and enter "BIOS SETUP".
Check the "Boot Options", to ensure that your RAID-array is listed as one (preferably the first) of the bootable devices.
Feb 22, 2015 | HEWLETT-PACKARD HP ProLiant DL380 G7 Base...
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
Reconfugure raid 1
Not sure what the questions is, reconfiguring a mirrored raid is a destructive process so all info on the drives will be gone.
That said this is managed through the SCSI configuration which you can get into at boot usually by pressing one of the function keys when prompted at boot up.
regards,
Mike
Sep 26, 2012 | IBM System x3400 M3 7379 Server tower 5U...
My hp proliant dl380 g7 server shows non disk error
Enter RBSU create Raid & Select Direct Attached Storage option in boot controller,
May 17, 2012 | HEWLETT-PACKARD HP ProLiant DL380 G7 Entry...
Raid Driver
send me you querry clearly to my email id:- venkatesh.k@cacheperipherals.com
Mar 15, 2012 | IBM System x3200 M3 7328 Server tower ...
Can not setup RAID 1 on an IBM X3200 M3 Server
you can access the raid controller using the BIOS and system devices>>> refresh>>> then select the controller then create your raid...
don't know why they move out from the POST the controller its really stupid''' Sorry..
Feb 04, 2012 | IBM System x3200 M3 7328 Server tower ...
Hello Sir, I need drivers for X3200 M3 7328 Model server. how can i download and install the drivers Regards P.Jana
What the paltform's dirvers you want?I have the Linux drivers of IBM System 3650,including the RAID tools etc.The difference of both server hardware is not too much.Maybe you can use it too.
Here is the drivers of website(in Chinese):
http://www-900.ibm.com/cn/support/download/driver/prosupport?category=13516&docordown=down
Feb 11, 2011 | IBM System x3200 M3 7328 Server tower ...
HP 1200W 12V 48VDC Rps for DL380 G5 DL385 G2  Power Supply Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
