Question about Canon PowerShot SX120 IS Digital Camera
I have 2 problem with my Camera Canon SX120 IS. i) while capturing the video audio is not comming. ii) while connecting it will TV black n white picture is comming. Please help me. Thanks in advance.
I have anproblem with my canon sx120is camera.my camera lens still is at on mood
Posted on Oct 15, 2010
My 10 second timer function doesn't work after I dropped my camera.
Canon PowerShot SX120 IS 10MP Digital Camera - Sam's ...
www.samsclub.com > ... > Cameras > Point & Shoot Cameras
Sam's ClubCanon PowerShot SX120 IS 10MP Digital Camera .... 2-sec./10-sec. delay, Custom*, Face Self-Timer** * Shooting start time (0-10 sec. ... 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Category, Transition Effects, Histogram, ..... just because it has a cover, doesn't mean it didn't work open in your pocket, or little fingers ...
Canon PowerShot SX120 IS Digital Camera 3.0 inch LCD ...
Jan 01, 2016 | Canon PowerShot SX120 IS Digital Camera
Audio video capture
are u able to hear the audio when you play back from your CAM?
Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
How to replace the lcd screen on the sx120 canon camra
Try this site:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Feb 16, 2012 | Canon PowerShot SX120 IS Digital Camera
When I connect my camera up to the one touch video capture card my diamond media the video camera picture flickers. Can you help me? thanks.
I had the same symptoms - black & white flickering image.
The problem was that my video source was PAL (European) but the software was set to NTSC (USA) video signal format. When I changed this, it was normal colour video without flicker.
I happened to be using AVS video recorder but similar settings probably exist in most capture programs.
Mar 28, 2011 | Diamond Multimedia ( VC500) Video Capture
What are the red yellow and white cords for i have a xbox
The side with 3 RCA jacks, red, white, and yellow, is for connecting the USB to a composite video cable. The black connects to an S-video cable; you would still use the red and white plugs to carry the audio. At least the older XBox's had composite video outputs; you just need the composite video cable (which you may have as they came with many video devices (VCRs, DVD players, video cameras).)
If you need to connect this Video capture device to another type of output, you will need a converter. Component to composite video would be one option. However, you will have signal loss with any converter.
I hope this helps.
(Composite video cables: yellow carries video, red and white connectors carry the Right and Left audio)
Nov 22, 2010 | Sabrent USB-AVCPT Video Capture
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Canon powershot A85 camera, only seeing black and white on TV
Please check Yellow video connector in TV and hook camera video cord there to see color picture of Canon A85
Feb 20, 2009 | Nikon Coolpix 5600 Digital Camera
Error in lens Restart camera
error with cannon powershot sd100, lcd is black,. how do you reset the camera.
Aug 25, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Startech USB 2.0 TV Tuner
Pls verify that the tuners color standard is identical to that of the video camera. Depending on where you are, there are a number of color system but dominant are PAL (for most European) and NTSC (for US). So you have to select which ever is being used by the video cam.
Hope this be of help.idea. Pls post back how things turned up or should you need further information.
good luck and kind regards.
Jan 25, 2008 | ATI TV Wonder 650 (DNH100715331) Video...
Canon PowerShot SX120 IS Digital Camera Logo
124 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
