I have a problem with the printer cartridge, that is my colour cartridge is empty and my black cartridge is filled, but then to i am not able to take a print out in black (HP Printer). Can i get some suggestions on this?
  • 4,737 Answers
Since you didn't mention the Printer's make and model, I can't make this specific, but what I am going to say is not different. There is no unusual problem, it normal and you can't print as long as the printer detects the color cartridge as empty. With some printers, it's possible to print color (high quality print, or only one color printing etc...) even without black cartridge, but not without color cartridge. The only thing you can do is, refill it or get a new cartridge.
If you need further help, let me know.
Good luck.
thanks for using FixYa.
Posted on Sep 08, 2010
Not printin g all the time & all blue
Without knowing the Model of Printer and any specifics I will try to cover all the bases I can.
If your printer uses a Tri-Colour cartridge and Black Cartridge then it is most likely that either the Magenta in the Tri-Colour cartridge is either Empty or Blocked or the Black cartridge is Empty.
To test this you can take the Tri-Colour and Black Cartridge out of the printer and press the Printhead against a tissue. The Black should be a solid black line approximately a centimeter long by 3 Millimeters wide. The Colour should have three solid lines, one of each colour Cyan, Magenta and Yellow. If either of these is not clear then the cartridge that does not leave clear footprints will either be empty or blocked.
If your HP printer uses seperate ink tanks for each colour then the Printhead may be blocked or the Ink Tanks are empty.
If it is a Laser Printer then there are several possibilities open. The Toner Cartridges are Empty or the Toner Seals have not been removed. If they are still full and the seals are removed then the Imaging Mirrors may be damaged or the Imaging Drum(s) may be damaged.
I hope that helps.
Jul 11, 2011 | HP Office Equipment & Supplies
Can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Aug 05, 2009 | Canon PIXMA iP1300 Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Black Ink has been re-filled, canon MP240 says its empty )=
i thnk you need to replace the cartridge maybe the ciruit has been destroy in the event of refilling the cartridge..so that the computer cannot read the ink level ..
I hope it help.
thanks for using FIXYA.
May 22, 2009 | Lexmark X3650 Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
I have a X3350 Lexmark printer. I do not require color printing at any time. How can I print black only using one black cartridge only. The color cartridge is never used.
let the colour cartridge be inside the printer.if its empty then also black will print.but its necessay that the colour cartridge should be in the printer as without the colour cartridsge in the printer the circuit does not gets completed.but the cartridge should be inside the printer if its empty no problem you can just print in black it will print.
Mar 02, 2009 | Lexmark X75 All-In-One InkJet Printer
How to use only black when the color is finished
you cannot use the printer by just keeping only 1 cartridge in the printer.as both the cartridges should be present in the printer then let the colour cartridge is empty what the problem is.you can print the black printouts with empty colour cartridge in the printer, but both the cartridges should be in the printer.and if still you get the message as colour cartridge is empty please replace the colour cartridge.the simple option is yopu can get the same cartridge refilled.as the cost of refilling is 10 times less then the new cartridge.
Oct 03, 2008 | HP PSC 750 All-In-One InkJet Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
109 people viewed this question
k24674
jasbo
jasbo
