Question about Take 2 Interactive Hidden & Dangerous 2 for Windows
Hi i have hidden and dangerous 2 just installed and we i go to load it up i get a message ''try to add the file
Send picture messege
1. In Idle mode, press <Menu>2. Press <Add> on the Subject 3. Enter the message subject and 4. Press <Add> on the Picture 5. Add an image file. 6. Scroll to the Sound line and 7. Add a sound file. 8. Scroll to the Message line and 9. Enter the message text. 10. Press <Opt.> and select Done.
11. Press <Opt.> and select Send. 12. Select an empty location. 13. Enter a destination. 14. Press <Send> to send the message
Or you can use samsung x640 "code" in my blog
http://pcgadgetdeni.blogspot.com/2013/02/all-phone-samsung-codes.html
Feb 14, 2013 | Samsung SGH-X640 Tri-Band GSM Camera Cell...
The free hidden and dangerous (1) gives errormessage: 'failed to host session' and 'failed to initialize network connection' when trying to start a coop LAN-game. When trying to start a coop LAN-game in...
Since windows 7 you cant Host a game anymore! The only chance to host and play Hidden & Dangerous Deluxe under Windows 7 is to install VMWare Player and then install WinXP on it (VERY EASY AND FAST, you need a WinXP CD or a ISO file). Then you have to activate Direct3D under the settings of VMWare and it installs automatically VMWare Tools. After this you can install H&D Deluxe on the VM and play the game in full resolution and full speed (fps) without any error!
This helps if you have problems with hosting a game under Win7 with these errors:
Hosten einer Sitzung fehlgeschlagen
Dec 28, 2010 | Take 2 Interactive Hidden & Dangerous 2...
Error message,failed to open file:igo/480_272/loading.bmp exiting application. clarion map 670 sat nav,seems to be in constant loop trying to pair phone on bluetooth and above error appears when selecting...
The solution that worked for me is: in your iGO installation folder, open SYS.TXT file then find section [interface] next check if exist something like this: skin="ui_igo8" if not then add it, but you must first check in your DATA.ZIP file what is the name of the folder it can be ui_igo8_da, ui_igo8_pda... depending on version. After that iGO will load normally. One more thing, I've added this section at the end of SYS.TXT file [loading] show_statustext=1 show_progressbar=0 progressbar_x=62 progressbar_y=174 progressbar_bmp="loading_progressbar.bmp" ;you can disable this line bu putting ; sign at the beggining loading_bmp="loading.bmp" ;you can disable this line bu putting ; sign at the beggining
Hoppe this will help you!
Aug 04, 2010 | GPS
I am trying to install an expansion to Hidden and Dangerous 2, it is called Sabre squadron. I have had this installed on this system before, and I never had this problem. When I try to install it; It...
Possibly the uninstall has not been complete last time you uninstalled Hidden & Dangerous 2 Sabre Squadron.
Try to run uninstall again and then install. Also delete everything you can inside C:\WINDOWS\Temp and use EasyCleaner...
http://personal.inet.fi/business/toniarts/ecleane.htm
...to clean the registry.
If still fails, try uninstall and install in safe mode.
As a final solution. Just do a clean reinstall for whole Windows. For such a great game it is worth it.
May 04, 2010 | Take 2 Interactive Hidden And Dangerous :...
I want read ebook on alfatel h1 mobile
I too have searched for PDF readers for china mobile.
But couldnt.
So, I converted the PDF file into TXT from "A-PDF Text Extractor".
After converting, I copied the TXT file into the Memory Card and opened it from E Book reader in H1. And it worked well.
Hope you'll try this.
Thanks.
Best of luck.
Oct 12, 2009 | Handmark Software MobileLists (950142) for...
Install problem
It sounds like the Windows installations are missing the language-library file LATIN.LNG that the STEP module is trying to load in order to work.
First. see IF the file is on your HDD via DOS commands:
From START search-bar, type CMD then click the CMD icon.
At the command prompt, enter
CD\
dir/a/s/b'find/i "latin.lng"
sit back... this takes awhile....
You can also redirect output to a text-file with >X:\phoundit.txt
X:\ being replaced with the drive-letter of your flash-drive.
If not found on HDD, check your Windows OEM install disks 2C if the file exists there, maybe stored in a cabinet file named Languages or similar.
If all else fails, the Microsoft website may have a download version of the missing file.
Nov 20, 2017 | Parsons QuickVerse 7 Essentials (fe11044)...
Hidden Program
In Windows 98 the MS fax client is installed as part of the windows messaging package and uses a mapi client like exchange client, outlook, or windows messaging to work. Try 'add/remove software' in the control panel and see if you can unistall windows messaging. If you have the win 98 install cd, there is a file called wmw-fax.txt in the tools/oldwin95/message/us folder. you might find the information in there.
Apr 07, 2008 | Microsoft Windows XP Professional With...
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Open Questions:
See all Take 2 Interactive Hidden & Dangerous 2 for Questions
Take 2 Interactive Hidden & Dangerous 2 for Windows Logo
90 people viewed this question
Top Take 2 Interactive Video Game Consoles & Games Experts
shaun
shaun
Bill Boyd
Alex Korvinus
Alex Korvinus
Level 1 Expert
Are you a Take 2 Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
