Question about Samsung Televison & Video
Have the 6165wx tv won't turn on flashes 3 lights timer lamp and standby/temp any suggestions?
    Scholar:
  • 128 Answers
The tv's lamps life span is about 3,000 hours of viewing pleasure. Some lamps exceeds and some barely reached the 3,000 mark, but when this happened you will not have any pictures showing, but it have sounds. This means that lamp is already burnt out and needs to be replaced.
Posted on Sep 08, 2010
  • 1 more comment
  • Konzen
    Konzen Sep 08, 2010
    The Tv's lamp lifespan is about an average of 3,000 hours of viewing. Some lamps exceeds and some just barely reaches the 3,000hrs range before they broke. So this means if you still have sounds and still have the power light when you try to plug the tv and turn it on it means that the lamp needs to be replace. I may advise to call the tv manufacturer in getting the details on how to replace the lamp.
  • joshpc10 Sep 08, 2010
    Why would the tv chime on then shut itself off would the bulb have something to do with that?
  • Konzen
    Konzen Sep 08, 2010
    base on my experience as a tv technician if the lamp flashes 3 times (whatever the tv brand is) it's an indication that the lamp needs to be replace. And yes it is the lamp that causes your tv to shut off.
Samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
May 30, 2012 | Televison & Video
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Mar 14, 2011 | Televison & Video
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Below are conditions lamp indicators that appear blinking and solutions:
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Aug 02, 2010 | Sony KP-65WS500 65" Rear Projection...
Samsung 56in big screen lights flashing-cuts off
theres defective caps in the power supply
Apr 25, 2010 | Samsung Televison & Video
Samsung
Replace the lamp - they only last about 2 years with 4 hours use per day.
Jun 21, 2008 | Televison & Video
Televison & Video Logo
90 people viewed this question
Henry  Thomas
Henry Thomas
