My Toshiba L550D will not turn on...On left side of the keyboard there is an orange light and in the middle there are two green solid lights and an orange light that is on and one green light to the right of the orange light that flashes intermittently. The computer has been working well until I tried to turn it on...perhaps I have hit a key when turning if off that caused this problem. Please advise. I am writing this request from another computer.
  • 62 Answers
SOURCE: computer won't reboot
Hi, I can help you with this. What shows on the screen when you power it on?
Posted on Sep 16, 2007
LRL Computer
  • 64 Answers
SOURCE: Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Posted on Sep 21, 2007
myob247
  • 1342 Answers
SOURCE: Toshiba Equium A200-1VO won't turn on
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Try starting it again.
Posted on Apr 22, 2008
  • 3 Answers
SOURCE: Toshiba Qosmio wont turn on
it is probobly the hardware
Posted on Nov 26, 2008
stabelabel
  • 51 Answers
SOURCE: HELP ME!! LCD SCREEN WONT TURN ON! TOSHIBA SATELLITE A215-S5837
it sounds like a hardware problem. I would say your high voltage board that drives your lcd has blown probably the caps you buy new on-line and replace it. send to factory service to have fixed. get fixed on warranty if you have it.
please let me if I helped
Posted on Mar 21, 2009
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
2000 villager radio wiring diagram
Constant 12V+ Green/Purple Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Green Dimmer n/a Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Light Brown/White Left Rear (-) Light Brown/Yellow Right Rear (+) Light Brown/Green Right Rear (-) Brown/Pink
Jan 31, 2014 | Car Audio & Video
Installing stero in car wiring diagram front soeakers 1999 mercury mountainer
your right front speaker neg side is Green with a orange stripe your right front pos side is Light tan with a green stripe your left front neg side is a light blue with a white stripe and the left front pos is orange with a green stripe,, a typical new radio will have a gray with a black stripe for the neg side and solid gray for the positive, on the right side and the left will have a white with a black stripe for the neg, and solid white for the positive, if you need anything else just reply to this feed and I'll help you
Oct 07, 2011 | 1999 Mercury Mountaineer
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
Needinfo on what wire does what on the Kenwood Excelon DDX7015, on the main harness and the little 3 wire harness near the center,
yellow-constant
red-accessory
if there is a light green,pink,or brown one is is us for brake ,
purple/white -camera or green/white
green/black-left rear- spk-
solid/green-left rear-spk+
purple/black-right rear-spk-
solid/purple right rear spk+
gray/black-right front spk-
solid/gray-right front spk+
white/black-left-front spk-
solid/white-left front spk+
brown or orange if any phone mute
black -ground
pink/white or purple/white or green/white-reverse camera''
Jul 10, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
Dell 17" monitor is not turning on.
1. Check the cable with the blue connector. Make sure it's plugged well to the back of the computer.
2. CHeck the light on the CPU's power button. If it's solid green, press the numlock key on the keyboard. Tell me, if the numlock light on the keyboard turned off or on. You can press it again if you didnt catch anything.
3. If there are no lights on the keyboard or the computer when you turn it on, the computer is the problem.
Just post here what lights are present or what happens when you press the numlock key.
Jun 16, 2009 | Dell P793 17" CRT Monitor
Right Turn Signal not flashing.
quick fix,try to run jumper wire from solid lime green wire to tail light green/orange wire Your problem is no power
Apr 21, 2009 | Plymouth Acclaim Cars & Trucks
Mercury cougar
Constant 12V+ Black/Orange Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Green Dimmer n/a Amplifier Remote Dark Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Light Green Left Rear (-) Tan/Yellow Right Rear (+) Pink/Light Blue Right Rear (-) Brown/Pink
Sep 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
Will not turn on. Toshiba 2060cds
I am having a hard time finding the manual for this older laptop, but, there is always a power button somewhere on the laptop itself, on the side, front, top of the keyboard, push everything and anything till you find it. Just plugging it in will not turn it on.
Apr 06, 2008 | Toshiba Satellite 2060CDS Notebook
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
